slow idle return
slow idle return
Sorry....2 questions tonight I guess......
Recently, I have noticed that the idle is slow to return to "normal" on my ride. To explain, on decel...or coming to a stop, at times the idle seems to continue to run high then....slowly return to normal. This is based on sound only....no tach on my ride, but it is apparent. If I stay at a full stop, it will very slowly come back down. Once it stayed high long enough that I "tested" it and without any throttle, it would pull me along when I released the clutch. It isnt constant.....but happens more and more frequently.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
RE: slow idle return
Exactly the same situation with my '04 WG. When I bought it, after running on the freeway for 20 or 30 minutes in the summer, it would idle really high - not even lope, but a smooth buzz. I dropped the idle some and it's better, but it still does it. I need to dig out (find) my old Sears engine analyzer which has an inductive lead for engine rpm and set the idle correctly. Mine's carb'd - coolrays615, is yours carb'd or EFI?
