No spark to 03 Ultra??
I have no spark to my Ultra. It started missing on the front cylinder when it warmed up, but ran fine for first 5 minutes. After reading other posts, I saw alot of Crank sencors going bad, so I put mine on my wifes 06 Street glide and no problems, so I exchanged my Volt Reg with an old one I had that was known good when I removed it. Now, no spark to either cylinder, I even replaced the coil and batteryl with hers and no help. I'm stumped. Any suggestions out there?
No codes, came home today, put it back together and it started, got warm then started cutting out again, pulled front plug wire, no spark at 2500 rpm to front plug. Found a stealer 45 miles away that had crank sensor in stock. Fixing to go put it on and see if that was it. If not, I guess I will take it to stealer for diagnoses, they said 75 per hour to diagnose the problem. Hopefully it was the crank sensor
Crank sensor fixed my problem, well one of them. I noticed about 2 weeks ago that it was cutting out between 5500 and 6500 RPM, and then the crank sensor went out, I thought it was related. After replacing the crank sensor, I warmed bike up and it ran great up to 5500. I just painted it about a month ago and I guess I twisted my fuel line during assembly, when I pulled fuel pump, I noticed the line was kinked down by the petcock, so after untwisting the line, I'm riding wheelies on my Ultra again. Life is good........
Thanks for the suggestions.......
Mike
www.mikestrikes.net
Mike
www.mikestrikes.net
Ras607
10-25-2011 08:18 AM
djpullen
09-11-2010 05:41 PM
