Power Vision Information Thread
#871
Hi JD,
Would you mind posting your settings for the throttle blade control? I have been wanting to do this, but have been waiting for information on this, in particular how much and which range of cells, and did you modify the alternate table as well?
Thanks for your help!
#872
Hi JD,
Some people set the last few rows to 100% of the column twist grip but as you can tell, I leave it just short. Seems to work better but could all be in my head.
Tweak it until you get a feel you like but don't go crazy.
#873
I have no idea how to modify the Throttle Blade controls or anything else on there lol. I have no idea how those numbers effect anything... Outside of the Spark Advance I'm pretty clueless. I would definitely like to know more about the other tables, though!!
Also, looks like I'll be pulling some more timing out. Not sure if I just got bad gas or b/c the weather is a bit hotter than it had been, but my bike was pinging constantly yesterday and even some this morning. So looks like I'll pull a little bit more out.
#874
Have a great 4th of July everyone.
#875
PowerVision and Heat Management
Ive noticed that the Dynojet Maps and the FuelMoto map for my 11 Limited have the EITMS set to 0 or off. Is this because we can turn it on and off with the throttle therefore dont need it to be set to 1 or on in the map? I also noticed that some of the maps have the compression releases turned off.
#876
#877
For any of you doing your tuning with the AT-100 Pro, I'd like some feedback. I’ve been doing some datalogs, probably 10 in all over the past week, but all until today have been fairly short. Today I did a 45-mile ride and created four CSV files, so here are some observations:
1. I have always gotten an occasional lean spike of 1.1-1.2 Lambda at cruise, and today saw some values between 1.5-2.5, but you can’t tell it when riding. You'd think running that lean would cause a misfire or detonation, even if between 1.1-1.2 and only lasting a short time. These spikes can occur on front or rear cylinder, and occasionally both together. I've also seen 32.767 on the CSV for a short burst only on decel, but only once. It shows 32.77 consistently on the PV Lambda gauges (front and rear) any time I decel at 0% TP above 3k RPM.
Later edit (07/04): I just looked at an old CSV from another participant of this thread, and he also shows lean spikes and even the odd 32.767 in places. Maybe the former are normal and the latter just some sort of reporting glitch that isn't representative of reality.
2. The bike is running very well from a seat-of-the-pants perspective, with only a pop or two every so often when I get off the throttle. The Decel Enleanment is unchanged from stock, so I may need to add some fuel (decrease the value). OTOH it would seem in viewing the CSV files that there’s quite a bit of inconsistency, with Lambda readings richer at one point and leaner in another under the same conditions.
3. What concerns me most is that today I completed three WOT runs from 2500-6000 RPM, each followed by another run to 5000 RPM in the next gear, but PV Tune doesn’t show hardly any WB2 hits above about 80% TP. In fact, I'm seeing only a few at 100% TP at 3000 RPM, and this is the only time I've seen any hits at 80-100%. OTOH the CSV clearly shows these WOT runs, so it would seem that PV Tune isn't seeing these. I had Min. Hit Count set for 80 (default) initially, then changed it to 40 today, and there still aren’t many hits, certainly not enough to tune the bike at WOT. The CSV shows it’s consistently running a bit rich at high WOT on the front cylinder, a bit lean on the rear.
4. Every time I do a datalog there aren’t any huge corrections, usually <10 for VE, but they seem to be consistent in size from tune to tune when I might expect the changes to be smaller over time.
#878
Hey Iclick my autotune pro with WB should be here on wed. I was hoping all the bugs would be worked out by now and it would be smooth sailing. Anyone else having tuning issues with AT pro? I have a couple of questions. Do you leave the wide band sensors in your bike all the time and if so do you get DTC's from the NB sensors being disconnected?
#880
