Power Vision Information Thread
Old 06-26-2011, 01:38 AM
Dustball's Avatar
Dustball
Dustball is offline
Originally Posted by ambrose
Noticed yesterday while riding with a buddy my speedo seemed to be a little off so when I opened up Winpv to look at my original stock tune under Gear and speedo calibration it says 2074 and the tune I have loaded it says 2179 , should I change it to the stock calibration?
If your error is roughly 5%, then yes, I'd enter 2074 back in as the Speedometer Calibration value.
-Dusty
  #832
Old 06-26-2011, 10:35 AM
ambrose's Avatar
ambrose
ambrose is offline
Thank-you
  #833
Old 06-26-2011, 05:32 PM
curlydee's Avatar
curlydee
curlydee is offline
Does the Power Vision remove the throttle lag on the 2011 fly by wires?
  #834
Old 06-27-2011, 12:59 AM
hornhonker's Avatar
hornhonker
hornhonker is offline
You can adjust throttle blade control all you like. Probably possible to make it so sensitive as to be undriveable.
  #835
Old 06-27-2011, 07:00 AM
JustDennis's Avatar
JustDennis
JustDennis is offline
The Power Vision can be used to adjust the Throttle Blade control. You can adjust the settings to remove the lag if you like.
  #836
Old 06-27-2011, 07:03 AM
JustDennis's Avatar
JustDennis
Originally Posted by bp_shooter123
Is there anyone who has access to the changelogs showing what changes were made when software or firmware is updated?
I know the software writers make them. Is there any reason they do not feel a need to supply the list of changes?
A normal changelog contains lists of bug fixes, improvements and other minor and major changes.
Michael
Looks like they listened to your request. DynoJet posted a new features file on their website with the other downloadables. Not quite up to the current version yet but it is a start.
http://www.dynojet.com/newdynojet/do...Power%20Vision
  #837
Old 06-27-2011, 09:29 AM
papifun's Avatar
papifun
papifun is offline
Originally Posted by JustDennis
Here is a start that I created quickly using some of Jamie's posts, my notes and adding information I learned from tuning. This is a first pass and will gladly take suggestions and corrections. Let me know if this is helpful. I tuned first with the stock O2 sensors and am now using the Autotune Wideband sensors. I can add that to the instructions later unless DynoJet comes out with a better manual first. Iclick, we can collaborate on this if you like. If this is helpful, I can take input and create a more comprehensive manual if needed.
http://www.box.net/shared/i66qvn4xf1s2xp7fgy8v
JD or Iclick ... what is differance if opening single or multiple logs when ask to open in Log Tuner ? I finally did some logs and following ure procedure JD....
would the multiple option of me opening 2-3 log files create a better avg when i click the CALC TUNE bar ?
  #838
Old 06-27-2011, 09:46 AM
curlydee's Avatar
curlydee
curlydee is offline
Thank you Hornhonker and JustDennis
  #839
Old 06-27-2011, 09:51 AM
JustDennis's Avatar
JustDennis
Multiple logs just provide more data. As a matter of fact, I used two logs this morning. Just be sure the multiple logs are captured using the same base map. Pull them both in to Log tuner and process as normal. I have used 2 log several times and they seem to work well.
I had a pretty big log from a ride Saturday afternoon while I was in the mountains. I didn't get a chance to create a new calibration from it yet and I created another log on the way to work this morning. They were from very different type rides but from the same base map, so I pulled them both in to cover more areas of the calibration. Hope that makes sense.
As a side note: I had been using PV Log Tuner 1.0.6 and just noticed that Dynojet had posted version 1.0.8 to their download website. I downloaded and started using it on this last calculations. I actually compared the output from 1.0.6 and 1.0.8 on the same calibrations, value files and logs and got same results. Just FYI.
  #840
Old 06-27-2011, 11:24 AM
papifun's Avatar
papifun
papifun is offline
thanks for ure great support... I guess logs will vary to if i drive aggressive or very conservative... Are best results obtained by not over reving the RPM.. i do like to shift at 4500rpm often.. if i roll off from a stop and lightly throttle vs a quicker take off till about 3500rpm and then shift - would these logs affect overall Basic tune performance ??? Is my theory true somewhat correct ? or it really doesnt matter how u ride when logging.. im very satisfied with the PV over the PCV... i just want a little better MPG compared to FM's map they sent with my setup..will test the new tune next week.. away at work...
Quick Reply: Power Vision Information Thread
