Power Vision Information Thread
Old 06-19-2015, 01:41 AM
gant's Avatar
gant
gant is offline
i read its normal but thought id ask, why when you run auto tune the bike runs very poor(running AUTO TUNE BASIC), theres not much power, and i get alot of backfire (is this normal) when i finish auto tune i run a code check, i notice that both o2 sensors have codes of rich , i dont think ive read of people auto tuning and setting these codes that would probably be why it would be backfiring ?
when i load the auto tune i also clear the o2 codes, the bike runs great with the auto tune loaded and no backfiring at all, im just worried about the rich o2 sensor codes (so far it only happens when im tuning)
  #7352
Old 06-19-2015, 09:22 AM
rubberheels's Avatar
rubberheels
rubberheels is offline
Default Auto Tune Basic
I need some sort of checklist on how to run a auto Tune. I copied one last year but lost it . I got it from this site but now I can't find it HELP!
  #7353
Old 06-19-2015, 10:58 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
JustDennis originally posted this a while back.
File Type: doc
  #7354
Old 06-19-2015, 12:37 PM
hscic's Avatar
hscic
hscic is offline
Here are some instructional videos from dynojet
http://www.dynojet.com/powervision/p...on-videos.aspx
  #7355
Old 06-19-2015, 03:39 PM
oldhippie's Avatar
oldhippie
oldhippie is offline
Getting codes and running with a lot of back fires isn't normal. Run Autotune a few times iteratively, save each tune and compare with the next one, and you should get to all cells you're hitting getting to within 5% of the previous.
Once you've done this hopefully your rich 02 sensors codes go away. If not it's time to start a bit of troubleshooting. Where did you get the base tune you are starting with? You should also understand that the bike won't run perfect when doing ATs, simply because AT Basic sets all cells to 14.6 (because that's where stock sensors work the best) and then retards your timing by 4 degrees (for safety purposes) so as to not hurt the engine.
I see you've been doing some mods to your bike, so you'll need a base map that should take your mods into account.
  #7356
Old 06-19-2015, 05:20 PM
gant's Avatar
gant
gant is offline
This is DURING the auto tune process is where I'm backfiring I read that the bike does run pretty bad while In auto tune I email Jaimie and told him DURING autotunr I get back fire and he said it's normal because of just the things you stated retard timing etc
After I finish my auto tune run and load it in everything is fine and no backfire or codes . I'm just worried that during Autotune I get codes. Jaimie told me autotuning could cause history codes
Once you've done this hopefully your rich 02 sensors codes go away. If not it's time to start a big of troubleshooting. Where did you get the base tune you are starting with? You should also understand that the bike won't run perfect when doing ATs, simply because AT Basic sets all cells to 14.6 (because that's where stock sensors work the best) and then retards your timing by 4 degrees (for safety purposes) so as to not hurt the engine.
  #7357
Old 06-19-2015, 09:18 PM
oldhippie's Avatar
oldhippie
Well, if Jaime says so, then it's true. He knows your build and he knows your base map, and has Mega experience. It didn't happen for me and I've not heard it happening much on most bikes, but you've got mods in there that may bring you outside the typical stage 1 ATs that most people do.
what kind of 2-into-1 pipe is that?
  #7358
Old 06-21-2015, 09:49 AM
topfun's Avatar
topfun
topfun is offline
Default Fast thoughts has popping
Need your advise when my bike sometime has popping when get fast thought. Thanks for any input.
  #7359
Old 06-21-2015, 02:47 PM
hscic's Avatar
hscic
hscic is offline
Could you clarify " sometime has popping when get fast" so forum members can address your issue? Do you mean you get popping at higher RPM? Is this during acceleration or deceleration? Is this during autotune? What kind of mods do your have? Have you flashed your custom map based on your mods?
It would just help understand the issues you are having with your bike.
  #7360
Old 06-21-2015, 08:48 PM
Red Dragons's Avatar
Red Dragons
Red Dragons is offline
Hey guys, I noticed something strange today while I had the PV connected and was just monitoring my spark advance while riding. I have my advance set to 20 at idle. When CHT reaches around 270 while sitting in traffic, the ECU increases the idle advance to 28. That's +8 advance. I have never noticed this behavior before and it's not part of any cooling strategy I've ever heard of since more timing would tend to increase temp, not decrease. I have EITMS disabled and idle spark control turned off as well. Does anyone know a reason for this?
Quick Reply: Power Vision Information Thread
