Power Vision Information Thread
#6961
I try to not get too concerned with spark knocks 2 or blow. I too have noticed that the front cylinder on my 14 Limited has to be richer by about 2 % in load areas to keep the spark knock down. The 10 limited I had the rear had to be richer. For some reason the harley stock maps have the idle and low speed area richer on the front cylinder also on the 14 limited. Haven't looked at any of the Dyna or Softail stuff or air cooled. I know the computers on the canbus systems is much faster and may be set more sensitive on the Ion sensing. I run a Data Log and look for the spark knock and check the VE's in the spark knock area and if they are little leaner there will richen them up slightly and problem usually is gone. If it isn't lean there then I look at the spark table and if it can be reduced without causing a performance issue will knock it down a couple degrees. Usually can be reduced as it is already backing the timing off when it detects spark knock and I don't notice it. One thing for sure it will keep you busy chasing it. Above 2 you can fix it below sometimes can be fixed.
BTW - when I asked about this at the dealership, a tech who I think is pretty sharp stated that the front cylinder on the new ones ran hotter than the back, due to the lowers and the fender blocking airflow (huh - none of that stuff is new on the 14-15's ?).. I didn't argue, but thought he was either pulling my leg.....now I'm not so sure.
Crazy Legs - I got lazy today - had to take SO to a flea market and too hot and humid when we got back. I'll grab a socket and swap 'em later.
Thanks for the replies - Ill post the outcome.
Edit - another question - when marrying the PV to a new ECM, does it remove any files from previous bikes it has been used on ( I'm talking the log and .pvv files..) And if it doesn't, what files are safe to clean off the PV - I know that my original map and the tunes in the 8 slots are all OK, but some of the log files have more data elements logged than others (i.e. some have "ionQ", others don't).
#6962
The rear is doing the random 1-2 thing. The front may be hitting a burst of them, but you are right, it's still not continuous. The ride the other day in +90 degree temp resulted in 3 or 4 on the rear and 95 or so on the front, in a 100 mile ride that included some stop and go and a fair amount of 50-70 Mph cruising. I'm not going to get paranoid over this, but do want to eliminate it before doing the stage 1 mods.
#6963
I agree- Especially considering the latest PV-2 and WinPV software will export and save the logged data, by default, in pvv file format. This is ridiculous because you cannot do anything with this logged data pvv file unless you can magically find an old copy of the Log Tuner software.
PV logs are saved in .csv format, logs can be viewed in the Dynojet Power Core software which can be downloaded here
http://www.powercommander.com/downlo...5449.19123.exe
A .csv is a very general format, it can also be opened in most spreadsheet programs including MS excel
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#6964
I'm having an issue with random knock count on the front cylinder ('15 stock 103 TriGlide). The other two 103's ('12 SG and a '14 Limited) showed more knock counts on the rear cylinder, which is normal due to more heat, this one shows an occasional instance of a knock event on the rear, but for some reason will show several at a time on the front. I'm running FM's "stock improved" map for the next month or so (gotta get home to Michigan before the "big" order to FM), but when I first put the PV on this bike, it was doing the same thing with a stock map.
Running MegaLogViewer on the last log file, I cannot seem to find a correlation between when the knock events happen and a change in Map, TP, or other logged parameters. I know that the ECM "thinks" it's a real event, because the front cylinder advance gets backed way down until the event is over and then advances again. I know that it seemed worse on a 100 mile run the other day, as the AAT was over 90 degrees, ET eventually moved up to 230 and head temp was running 270-290, but again, I've seen this when it was much cooler. What I am suspecting is either false ION knock sensing due to a bad plug or plug wire, but am wondering if there are other reasons for this issue..
#6965
Interesting- I loaded a few of the canned tune files from PV's recent database into WinPV and ran Compares between the files. the tech's were not kidding. The files are EXACTLY the same on all parameters and settings. The only thing different between these canned tune files is the name of the file.
#6966
Been two seasons i haven't used my PV, i replaced my slip ons from V&H Ovals to V&H 4.5 hi Output Monster Rounds. I just updated all software for my PV. Can i have a quick refresher on correct way to run Data log and then view the log so I can send to FM for help. I think i got some knocking going on. What file do i need to send FM ? No one in my area still doesn't use the PV but only the SEPRT which i had and didn't like it.. not as user friendly..Is there a current link i can go to with detail instructions ? I want to make a economy tune and a power tune... Can i do this with just adjusting AFR or do i need to adjust VE tables too.. If i try to run with Basic Autotune , the bike runs like crap. feedback would be great. Yes i bough my PV from FM 4 years ago.
#6967
in my opinion the more automated it got the more dumbed down it got. I really like the automation for the VEs however I still keep a eye on them because it seems like there's always some area that goes weird. I really liked having log tuner available and supported. just don't see how it would be that difficult to at least give it minimal support and let people utilize it that want to.
I haven't really had any spark issues with the Fuel Moto map for my 14 SG. and I admit I don't understand how it works it just has not sunk in how it's recorded and the CAN bus system. all I've seen is little snippets and comments that I have yet to really read a full explanation of spark knock knock on the CAN bus and how it's recorded with the Power Vision
#6968
Some knock activity is absolutely normal, especially on 14-15 CANbus models as knock retard is slightly different. Remember knock retard is based on sudden increases in cylinder pressure, not actual detonation and the number of knock counts is relative to the duration of the log or run cycle, you really need to look at overall knock retard activity. Also note on 14-15 bikes the knock retard channel is not individual knock events, it is adaptive knock retard that is learned. That is why your logs look funky in megalogviewer, they are the adaptive values not the knock events themselves
#6969
A .pvv file is not a log file, it is a value file which is an individual table or tables within a Power Vision calibration, .pvv files can be imported in the WinPv software.
Running though DJ's instructions on starting logging, the default process I encountered with the PV-2 when I exported the captured logged data through WinPV's "get log" operation, WinPV saved it with a pvv file extension. The DJ guide shows it being exported as a csv. I can't tell why my unit, by default, chose to save it as a pvv. The log settings in the PV2 were set to simple and not "pro-xy"
I eventually figured out how to open the pvv in WinPV using the "load values" menu option, but again, I have no idea why the PV-2 would export logged data in a pvv format. I was data logging and not auto tuning.
You may want to grab a new default unit with the latest firmware to see this oddity.
#6970
You are correct and that was my mistake for not being familiar with the software- the VE's are different between all of them, and I'm understanding now that having VE correct is key. Everything else though is 100% the same among these map files. None of these maps are for my specific set of pipes, yet I have different DJ techs saying use different files such as the one for Rinehart, Big Shots, and telling me 'oh they are all similar and do the same thing'- which tells me, they don't think VE matters all that much and neither does accurate tuning. Very disappointing from my side, is all I'm saying.
