Power Vision Information Thread
Old 02-28-2015, 08:53 AM
04ctd's Avatar
04ctd
04ctd is offline
Originally Posted by Smokey Stover
rc4life, Have you Exported learned values-Saved to a slot - Then flash to ECM and then re run Autotune? 1k miles is a lot of riding at 14.6 AFR across the board.
agree with this guy, you are not doing something 100% correct. i have a hard time with all the steps if i dont do one for awhile.
FWIW, in your case, your PV is WORTH the money, iffin i was you, I would use Quick Tune, and enrichen the low end.
Decel is at time 2:06:
here is a link to time 2:06
https://www.youtube.com/watch?featur...Zfc0UNHk#t=114
after that, I would autotune, to smooth out the tune.
you just gotta put enough effort into it.
  #6852
Old 02-28-2015, 11:02 AM
FinalShot's Avatar
FinalShot
FinalShot is offline
I could be wrong but I read his post as he's using a base tune that was sent to him and he hasn't tried AT yet. Maybe I'm wrong but I don't think he's cruising around in AT mode.
  #6853
Old 02-28-2015, 12:24 PM
Smokey Stover's Avatar
Smokey Stover
Smokey Stover is offline
Originally Posted by rc4life
So I ordered my powervision from my local indy. (big mistake, should have gone through fuelmoto but didnt know about them)
And the bike decel pops like hell. I have been using basic autotune for over a thousand miles now and hasnt helped...
Keep in mind, I am a complete noob at this tunning stuff so tuning it on my own is something i dont think I can do..
I interpreted The OP's post to mean He's been running Auto Tune for 1k miles without exporting and reflashing. Hope not but It'll be interesting to hear from him again if so.
  #6854
Old 02-28-2015, 12:29 PM
Smokey Stover
Also as a side note, That Header looks cool but it may have some decel pop no matter what. And there are true dual maps for short pipes on DJ's website that might be closer to start with.
  #6855
Old 02-28-2015, 02:28 PM
rc4life's Avatar
rc4life
rc4life is offline
Ok thanks for all the replies guys. What I mean is I have the map That pv sent me(the rush 2-1 map) and I have been using auto tune and exporting it to the PV map for a ton of times over the course of over a thousand miles. There is no way it should decel pop nearly as bad as it does.
  #6856
Old 02-28-2015, 03:51 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Can you post your latest calibration and the one you did before that? Most of the time you are in a long decal you are below what the stock O2's can collect as far as data. Meaning auto tuning will not do anything for popping.
I have tuned that pipe and you are not stuck with the popping.
  #6857
Old 02-28-2015, 04:01 PM
FinalShot's Avatar
FinalShot
Also, double check to make sure you do not have any exhaust leaks. Wouldn't be the first time I have seen guys with bad decel popping that had exhaust leaks.
Also, what are your in the 20 map area from 2000 rpm and down?
  #6858
Old 03-01-2015, 09:17 PM
SpinnrUp's Avatar
SpinnrUp
SpinnrUp is offline
Default PV software version question
I sold my scooter and included the PV in the sale and am about to purchase a new one from FM for my 2014. It's been a while since I've even looked at the desktop software and I wanted to check for available updates. My desktop software shows that it's version 2.0.6.1319. Looking at the DJ site, the current version for download is 2.0.5.1319. Did they roll back a minor version step? The current download file also is named 2.0.5.1319.
Thx
  #6859
Old 03-01-2015, 10:58 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
Thx
2.0.6.1319 is the latest. All you have to do to update just the software is go to Update Client under the program Power Vision program file. If you are hooked to internet and Win/PV closed open the update client and click through a few boxes and it will eventually pull up your current and latest version. Once you get your new PV need to hook it up and update before installing/marrying to bike.
  #6860
Old 03-02-2015, 09:08 PM
SpinnrUp's Avatar
SpinnrUp
SpinnrUp is offline
Sounds like the version available on the DJ download page isn't the current one. It shows as version 2.0.5.1319. The updater software must be pulling the 2.0.6.1319 as the latest. I'll be finding out soon.
Thanks
Quick Reply: Power Vision Information Thread
