Power Vision Information Thread
#6741
Here's what mine looks like:
750 through 6,000
0.936
0.936
0.923
0.882
0.873
0.873
0.873
0.852
0.856
0.856
0.856
0.856
0.856
0.856
0.856
0.856
0.856
Or, as you have yours viewed:
13.8
13.8
13.6
13.0
12.8
12.8
12.8
12.5
12.6
12.6
12.6
12.6
12.6
12.6
12.6
12.6
You don't have to go this low, or maybe what I'd do, is start with these numbers and see if you get a decel pop. If you do get a pop, I'd look for an exhaust leak. If you don;t get popping, then you could try increasing the number (make leaner) to see when you get decel popping and then back off a little from there.
#6744
I used something that a couple folks here recommended and then modified to work for me.
#6745
I picked up a locked PV along with the AT110 wideband sensor kit and will be buying an unlock code to use this on my 2002 Fat Boy.
Question I have is can I use this on my 2010 Ultra to read/record the AFR to verify if my TTS tune needs to be adjusted? (So not marrying to this bike just read/record/monitor.)
#6746
#6747
but to answer the OP's question, TTS MT8 files lock the ECM so you won't even be able to get into it without flashing the stock map back into the ECM which defeats your purpose..
#6748
I have a PV sitting on the work bench that is married to bike that I sold. Maybe I'll hook it up and see what I can get. I've been meaning to sell it.
#6749
I was just wondering if I could log data with the PV that included the AFR from the widebands. If I can then I could compare it with the AFR/Lambda being requested by the TTS tune.
Probably be easier just to buy another license for the ultra.
#6750
