Power Vision Information Thread
#4852
I have a quick question on installing auto tune. Been searching for the answer, the instructions are not completly clear. When installing auto tune for the PV-1, if the header (FM 2-1-2) has both bung type connections, can both 12 mm and 18mm be installed or should I remove the 12 mm?
Thanks..
Thanks..
#4854
Thanks..
Thanks..
#4855
So the answer I get about that is that the 14.6 in this table is a "software switch" which then refers the software to the Closed Loop Bias setting and when that is 720 you are at the riches end of the settings. = approixmately 14.2AFR
I'm a pretty much a noob, with enough info to be dangerous, but this is the explanation I received from both DJ and FM. so YMMV
#4856
If i remember right there is some different functions between the sportster programing and my bike. i have a street glide. i think there are some things you can turn on in my map that the sportster maps dont support. It is not the map it is the functions of design from moco. Like i have an EITMS system and i dont think the sporttys do.
How many AT runs have you done? Are you using narrow band sensors or wide band? if you dont have a cat, what do you have for a head pipe? Aftermarket or stock cat removed? stock a/c?
#4857
Hi Boston Chris,
I have done 10 AT's so far, each one is pushed a little farther to fill in as much of the cells as possible. The first 3-4 AT's were easy running with a high of ~20-25% throttle position and ~4000 max rpm's. Most of the VE's went richer ~5-10%.
Every tune after these (6-10) resulted in many cells running leaner than before and a number of them leaner than stock. Every thing over 60% throttle position went leaner than stock.
I have a stock head pipe, stock AC and stock slip-ons. The whole bike is stock and is NOT a California bike.
I am running stock narrow band O2 sensors that show no problems. I can change the CLB to a richer setting i.e.: ~14.4 ARF (786mv) and can tell they follow, engine runs richer in closed loop and shows no surging but I've read that it is not good to push the O2's like this and they are not really very accurate at this level.
Today I ran AT #9 & 10 and did a lot of roll on's to fill the chart as much as possible, hoping more data would help. It only made it worse. It even changed VE's outside the closed loop area (ie: wide open 80 & 100% TP) to a leaner VE setting!(~5%). Ouch.
I was surprised that the PV would change the last two columns (80 & 100% TP) since these columns are not set to 14.6 AFR that AT sets up and needs to acquire data.
I'm thinking of maybe running the Power Commander VE's (rich ~20% from stock) Harley's stock AFR's and Timing to see what happens. At least I would be starting off rich and the ARF's and Timing is safe.
#4858
#4859
Both Narrow and Wide band installed
Thanks..
Thanks..
#4860
i have a 2011 blackline, 96" motor, aftermarket intake and pipes.
any reason why active compression release should be enabled in my tune?
looks like it came that way from the factory but i am a little surprised it would be turned on or even a physical feature in that engine.
edit... when i try to run the bike with it turned off it throws a code p1 655
