Power Vision Information Thread
Old 06-23-2013, 08:40 AM
iaff84's Avatar
iaff84
iaff84 is offline
Originally Posted by nhrider1
Reverse the sensors...if the fault moves to the rear, you have a bad sensor.
Good idea. Did it and it still reads WBF:L.
Also have a red light flashing on auto tune unit.
Dennis
  #4782
Old 06-23-2013, 10:19 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Dennis
OK... I was expecting WBR:L if the sensor was bad. Did you swap the sensors or the cables? If you swapped the sensors and the fault stayed on the front cylinder, then you may have a bad cable. If that is the case then try swapping the cables (either end) and see if the fault moves to the rear cylinder. That would indicate a bad cable.
  #4783
Old 06-23-2013, 10:25 AM
tcrideshd's Avatar
tcrideshd
tcrideshd is offline
6th Gear
Guys I have ran some autotune runs and have flashed the latest. Where do I find and decipher the results and what is the numbers I need? Thanks guys
  #4784
Old 06-23-2013, 11:00 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Download your last 2 tunes to your PC using WinPV. Open your most current tune in WinPV. Open the previous tune using Load Compare.
-You want to view VE's (under Airflow).
-Click on the Delta tab in WinPV. This will give you the absolute difference between the last two tune files.
-Observe both front and rear VE's
-When you get that number less than 3-5% you're good.
-Move on to look at timing if you like.
  #4785
Old 06-23-2013, 12:27 PM
mibeaulieu's Avatar
mibeaulieu
mibeaulieu is offline
I've been using power vision with my fat bob - I have a stock bike with VH Big shots and an after market air filter. I've run Basic AT a couple of times - what does this table show? Any thoughts?
  #4786
Old 06-23-2013, 01:49 PM
iaff84's Avatar
iaff84
iaff84 is offline
With the bike running and cable cut loose from bike, I went along cable bending it and sure enough, started working on front. Cut back covering and wire was broke. Soldered up and all is well. Thanks for walking me through it.
Dennis
  #4787
Old 06-23-2013, 03:08 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
That's a typical VE table.
-Load the previous map using Load Compare
-If greater than 5-6% you need to run more autotunes until the deltas come into range. Always compare your final run to the run immediately prior (last 2 runs).
  #4788
Old 06-23-2013, 03:59 PM
cbrown@woods.net's Avatar
cbrown@woods.net
cbrown@woods.net is offline
Default Temp related shift in VE tables
Anyone else done more than a little AT spread across a wide temp range? Say 35F - 90F?
Have noticed here that _peak_ VE (highest 3 - 5 cells) tends to be 5 - 8% lower at < 40F than it is above 80%,
and that (centered on around 65F) the pattern stays the same, but the main hump tend to shift a cell or 2 up/left on the cold side and down/right on the hot side.
  #4789
Old 06-23-2013, 04:38 PM
RJHD's Avatar
RJHD
RJHD is offline
Default Getting a tune into WinPV
So, I've searched and played with WinPV for an hour or so and can't seem to figure out how to get my PV tunes into WinPV.
In WinPV, I go to...
PowerVision, get tune from PV..
Pick the tune I want and hit OK...
Get a message "Tune is ready for editing"
So, I go to Open, navigate to the "tune files" folder I created and nothing is there?
Feeling stupid here...what am I missing? Where is the tune being downloaded to?
  #4790
Old 06-23-2013, 04:44 PM
RJHD's Avatar
RJHD
RJHD is offline
Default Sheesh
I see it's already in WinPV under tune items...lol
sorry...
I did an hour or so auto tune today and am wondering what the data is telling me. If I post a pic of the air/fuel ratio, can you folks tell me anything about it?
Quick Reply: Power Vision Information Thread
