Power Vision Information Thread
#3831
Thanks Jamie, this is a learning process I know and I really like learning about everything so this is something I can get my teeth into so to speak.
As far as tuning out every knock event, I understand what you are saying here too. I am only working on mine because the knock showed up at the same rpm and map cell every time it showed up in the logs. Now it didn't show up every time I hit that cell so it was intermittent, but when it did show up it was at that cell with it showing up 4 times in a 14 minute log file. That is the reason I felt I could tune that out. I pulled 1* in that area just to see if that stopped it or made it a rare event.
Thanks for everyones help. I am pleased with my results so don't misunderstand my questions here, just trying to learn and get the best out of my tune as I can.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#3834
Power vision tuning
Help me understand a few things about EFI tuning? I've been using a FUEL MOTO MAP installed with PV since May 2012. I have a 2012 ULTRA LIMITED and have installed a FUEL MOTO JACKPOT HEADER, 4" RINEHART SLIP-ONS, and SE cold air intake, so far I've not done any tuning so MAP is still as delivered and bike runs great. I made a big leap from a 1982 shovel and have been riding HD since 1972 and have always done my own repairs, but this EFI stuff has been a struggle. I've read most of this thread and have been following it a long time and have read some books (waste of money) and have read the users manual for PV, it's also vague in several areas, recently read the MASTERTUNE user manual and it actually helped a lot and is well written (Sorry Jamie). I can grasp the basics of how it works but there a few fundamental things not very clear to me so hopefully someone can enlighten me. How does the ECM use the AFR and VE table? Am i correct when i say you wouldn't even use the AFR table if in complete open loop, the VE table is what would provide the ECM with how much fuel to use? And in my current case the narrow band O2 sensors are what link the two tables values by comparing the target AFR where the value is .981 lambda with the O2 sensor reading and then calculating the difference and then store an adjustment value to the corresponding value in the VE table for future use? So, if you was to use broadband O2 sensors the entire AFR table would be used and if after dialing in the VE values and you decided to run completely open loop only the VE table is needed? I hope I'm finally getting this, of course I do realize there are other tables and inputs that come into play, it's primarily these two tables and how they relate that has had me in a tale spin. Thanks for helping out someone leaving the stone ages!
Louis
Louis
#3835
my understanding is limited also . Here is kind of how I see it and please correct me if tthis is wrong . the bike does use the afr .. The ve is air flow for your engine. if the ve's are not right then when your ecm is trying 14.6 or whatever and the ve is telling it it's at 14.4 but its really at 14.2 the ecm is chasing a false number and could be leaning out or running your bike to rich . Thats why you want to dial in your ve 's first.
the ve looks at if The throttle or rpm is at 2500 rpms , then Im moving this much air .
the o2 sensors says ok if your moving this much air at 2500 rpms I am detecting 0.898
The afr says ok if your moving this much air at 2500 rpms I am looking for closed setting 0.986 so I need to cut off some fuel to get where I should be
#3836
The engine is running based on what is defined in your VE & AFR tables. The ecm looks at the tables and calculates a pulse width to deliver fuel to the engine. If the VE tables do not match what your engine is actually doing then the fuel delivery will be incorrect, you could be running leaner or richer.
By running Auto Tune (Closed Loop) you are dialing in your VE’s tables to match what the engine is actually doing. Once you get your VE’s dialed in, your AFR should be correct with little to no corrections made. At this point you can change your AFR to whatever you want including open loop.
Once dialed in and in open loop your ecm looks at the VE and AFR table and delivers fuel based on what is defined in your map. In closed loop the ecm can make small adjustments for things like elevation changes.
#3837
Louis
Louis
#3838
Power vision tunning
Thanks to all your resposes, and stailjim61, your explanation was very near to what Jamie Long at FUEL MOTO (thanks Jamie) told me over the phone today. I can't believe that with all the research i did and even after reading the PV users guide i was not able to determine what really should of been a basic concept. But i got it now and feel confident that i can now start doing some AUTOTUNE data recording and understand what I'm looking at. Looking forward to the fun.
Louis
Louis
#3839
Hey all, newb here to the tuning section, first off about my ride. its a 12 SG with Big radius pipes and thunder baffles with torque cones, also running a PM A/C. Ive ordered a PV and flashed a tune already after saving the stock of coarse. it seems to ride like a champ so far! ive only ridden it this morning for about 20 min. but to be honest, im not reading through almost 400 pages of info on this PV tuner.
the instruction booklet is a GREAT dissapointment!!! it dosent explain any of the features or functions in any length of detail or even how to really use anything. so far i was only able to get as far as i am now through google, youtube, and this site.
can someone explain to me what if any gains i would get if i used autotune? also is there a set mileage or time to run auto tune to get an accurate tune?
#3840
Can someone help me my pv cuts out after about 2 minutes of running if you are in the gauges all the figures disappear but the main screen stays on and if you are auto tuning it just stops recording and you still have the main screen on.
If you turn the bike off and then restart it all works fine again then it stuffs up again. Help...
