Power Vision Information Thread
#331
#332
The weather has been so crappy in the NE it's been impossible to get much riding in. Hopefully we get some sunshine, some drying out and some mileage to see how the fuel useage gauges on the PV measure out.
#333
The weather will not cooperate just heard on news we are on pace to be the coldest April on record here. Then the one nice day we had I was re doing a push rod that come loose. I am very anxious to ride and play with this thing.
#334
#335
Same problem here, the weather is not accommodating us.
I did notice a small change to the distance gauge (miles). Originally when I did some testing, the readout matched my bike odometer exact. However, I also noticed that my speed calibration was off. After fine tuning the speed calibration, there is now a difference between the odometer and the PV of .1. I will need more miles to test if this is consistent.
I have not forgotten and will post my findings as soon as this weather pattern breaks.
#336
#338
The CAN cable and J1850 splitter, both needed to feed the AT-100 data to the PV, are supposed to be ready for shipment at any time. As of yesterday Jamie hadn't gotten any in but he said he would let me know when they arrive. The AT-100 Pro kit and the official-release of the PVTune software should be ready at the same time, which is only a presumption on my part. PVTune is in beta now, but AFAIK only DJ and Jamie are testing it. Jamie is giving glowing reports on it as an effective tuning tool.
The cables can be fabricated, but I haven't been inclined to do that, as I don't want to hack on my existing wiring unless required. Besides that I already have a tune created by the AT-100 when it was on the PCV, so I don't think I'm going to benefit much from it in the short run--so I'm in no hurry. But if you have AT that you were using with the PCV like I do and you're hot-to-trot to get it working, you can extend the CAN cable that goes from the AT to PCV using four wires from a CAT5 cable. The problem with this is that you'll also need the software, which is still in beta and hasn't been released yet AFAIK. The J1850 connector only feeds 12V and ground to the AT-100, so you can splice red (12V) and black (ground) on the J1850 and you're done.
#339
Quick Update
Ok weather broke for today and I was able to get in a full tank of riding.
1. My speed calibration was off. My speedo read slower than I was actually traveling. Changed the speedo cal from 2206 (Stock) to 2270. Appears to be on the money now.
2. Previously I stated the bike odometer and the PV trip miles was off by .1. Scratch that, Both A & B trip miles are on the money with the bike odometer.
3. The PV MPG on this tank was 28% higher than actual.
I will be monitoring the next several tanks and will report back if I see any significant changes.
#340
