Power Vision Information Thread
Old 08-09-2012, 05:49 PM
jbrushoe's Avatar
jbrushoe
jbrushoe is offline
[quote=iclick;10182202]I'm at 14.0 there and am having no problems either.
You might try extending your 14.2 rows on to 80KPA. It doesn't take much throttle to hit that level and you're quite rich there, which may affect your mileage if you are running there often enough.
Ya, I might give that a try. As far as fuel mileage I average about 44-46
and she runs like a striped ape. Those woods Triple 5 cams really woke her up.
  #2872
Old 08-10-2012, 06:01 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
Originally Posted by iclick
Yes, that should be rich enough, but you might look more closely at your VE tables. You may be running into the same problem I had. For some reason I was getting progressively leaner in one area (~3k RPM IIRC @ 0% TP) for each tuning session. The changes were so small I didn't notice and after a few dozen datalog runs the VE values had decreased by around 20%. That was enough to cause decel popping.
I would suggest that you compare your VE values at 20KPA (or 0% TP) with those in the tune you started with before tuning with the PV. If you see what I experienced just use the stock values, and if you're getting no popping just leave them there, then eliminate those areas from future tuning. I've had no popping problems since doing that.
Looking for a reason for this, I asked Jamie who said muffler characteristics can cause this sort of anomaly--most of it from reversion or exhaust leaks, as Dennis has already mentioned. The 0% TP column is problematic with so many exhaust systems that DJ recommends not auto-tuning there with the PCV with Auto-Tune (closed-loop with WB O2 sensors).
Thanks for the suggestions. I've only done one tuning run so far and all of the changes were small. Also my 20kpa column AFRs were not in closed loop so I don't think any of the 0% TP VEs changed, but I will go back and look to verify.
  #2873
Old 08-10-2012, 06:04 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
Originally Posted by jbrushoe
Of course I'm running open loop & different sleds but in my 20kpa I have it set at 13.9 & it works great for me. Here is a shot of my AFR.
Thanks. My AFRs in the FM map Jamie sent with my PV are 13.0 and 12.5 already so I think that should be rich enough. Think I am going to start over with the FM map and use the Autotune to do some runs and see what changes.
  #2874
Old 08-10-2012, 06:11 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
BTW, I wonder why my calibration shows a 27 and 85 KPA column and yours doesn't.
My calibration for my 2011 Wide Glide also has a 27 and 85 kpa column. Maybe its specific to the calibration for certain models. I think mine is a 176 calibration if I remember correctly (at work so don't have access right now)
  #2875
Old 08-10-2012, 08:26 AM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
Depends on where the base calibration came from.
  #2876
Old 08-10-2012, 11:04 AM
iclick's Avatar
iclick
iclick is offline
I assume you're running 12.5-13.0 at WOT, not below that, which is in open-loop and not an area that can be tuned with the stock NB sensors.
  #2877
Old 08-10-2012, 11:13 AM
iclick's Avatar
iclick
iclick is offline
I don't know unless it has something to do with my 141 strat??
No, you aren't alone. I just checked some tunes I have here to add to the list:
2006 FLH-Strat 141 (Jbrushoe): No
2007 FLH-Strat 159: Yes (27 and 85 KPA present)
2007 FLH-Strat 176 (mine): Yes
2008 FLH-Strat 205: No
2010 FLH-Strat not shown: No
2010 WG-Strat 176 (MMXIWG): Yes
The common variables here are that all non-TBW with O2 sensors have the extra columns.
  #2878
Old 08-10-2012, 11:18 AM
iclick's Avatar
iclick
iclick is offline
They wouldn't change if in open-loop, so I guess that's not it.
  #2879
Old 08-10-2012, 11:38 AM
Delta's Avatar
Delta
Delta is offline
2012 Ultra Tri Glide
Strat 44
No
  #2880
Old 08-10-2012, 04:38 PM
pusher52's Avatar
pusher52
pusher52 is offline
Stage IV
Stray 44
No
Also like Delta 2012 TriGlide
Stray 44
NO
Quick Reply: Power Vision Information Thread
