Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Does loading the new software remove any tunes that are saved on the power vision? When you say you dont need a pc to tune does this mean you can datalog and then calculate new tunes right on the power vision?
No, the tunes will remain intact on the PV when you load the software. If you choose to do the autotune on the PV it will ask for a slot to put the revised tune.
Just sent an email to dynojet to be a beta tester. Do I have to wait for their instructions? Will they send additional documentation as to how to use all the features; or, is what is at box.com everything?
I'm thinking of going back to the FM tune that I started with and begin anew. How many times do you think I will have to autotune before the delta is less than 1%?
Once VEs are set, do you still use autotune to adjust spark advance or go you use the quick tune?
If this works as advertised it will greatly shorten the time it takes to presently tune. I think I understand the EGR concept as I used to use the TTS. Does the beta version automatically makes the adjustment or is it inactive at this point?
Do many questions but then again, discoveries are made through mistakes.
There is a new DOC file, 8-7-12 with a newer firmware.
