Power Vision Information Thread
#2421
#2423
I have a copy of stage one down load that i bought when i did stage one on my 10 street glide. I think its connverted to pvt. Or what ever for power vision. PM me e mail addy. I can try to send it to you. Obvious if i figure out how to do it YOU USE AT YOUR OWN RISK. LOL.....
#2425
#2426
Can anyone tell me what changing the engine displacement does, Im guessing that you can raise or lower the entire fuel curve with this setting? I have a map were the displacement is set higher than the engine it was done for and it seems to be rich across the board, I was going to lower the displacement to get it in the ballpark, what do you guys think?
Thanks...
Thanks...
#2427
Thanks...
Thanks...
#2428
First, download this tutorial on basic tuning and read through it. You can use the logs you already have in addition to others you'll create later, as the PV Tune software can load more than one log file in one tuning session. One you read through the PDF, post any questions that you may have.
I am tweaking my current tune little by little. I upped the AFR in the AFR table by .2 pts for the cruising ranges but left the rest alone. I will take it out for a ride tomorrow and see how things are.
I looked at the 2006 tables for the configuration that matches my bike and the tables, thought similar, have AFRs that are about .3-.4 pts above my AFRs. the VE tables are close for the fronts, but totally different on the rear cylinders. The VE tables on the 2006 are similar for front and rear and mine are way different. Probably as a result of the dynos sensor not reading the rear cylinder exhaust correctly. I was thinking just for the heck of it, copying the tables from the 2006 into my bike and see how it runs.
What is tuning? Part science, part guessing and part experimentation, RIGHT?
