Power Vision Information Thread
#2321
I have had mine to 920, but I didn't like it.
The SEPST will allow you to set it as low as 800 RPM.
Also my bike runs better if I let the rocker boxes get warm. I guess it give the computer time to run its checks for all temps up to running temp. I ride with a lot of evo guys and older engine bikes, and they always let their bikes warm up good before riding out the first thing. I guess I picked it up from them, but I can positively say that my bike runs smoother if I allow it to warm the boxes a little. That is my gauge to know that the computer has had time to do its checks.
#2322
I run with my warm idle set at 950, and like how it behaves vs. stock (higher) setting.
At start-up, I let the bike sit for a minute or maybe a bit less before taking off. Use the time for ear plugs in and gloves on. Probably also a bit of a hold-over habit from my Evo/carb days - when it was more like a couple of minutes, when I could back-off the enrichener. I really take it easy, and don't get much into the throttle until the bike is warmed-up, though. YMMV.
#2323
#2324
I get my info from my experiences. Everyone says each bike is different.
I know when it is cold outside or cool in the mornings, if I ride before the hiss from the a/c has stopped, ans the bike hasn't warmed for a minute or so, it rides like ****. Vibrations are rougher, and it just doesn't run right.
Even by making the general statemen that the hd tuner wil allow the idle to go down to 800, despite the calibration map, I was still correct.
There isn't anything wrong with the way I handle my initial start up, nor is there any issues with my bike.
It is the relationship I have with it, and we get along just fine.I
I am not being a SA. I can't explain it. I have always let my air cooled bike warm up, and they ride better for the day Don't, and they are fussy. Be it efi or carbed. If they ride good for you in four seconds after start, that is a first for me. But that it awsome.
#2325
Engine temps...
2011 FLHTP..103CID,oil cooler....stage one..Power Vision..using DJs MAP for this bike w/V&H slip ons,hi flo air box......@ appx 80F I am seeing 240-270 F engine temps...is this too hot?...also,I am having a problem using my LOG files...I am following the directions but I cant get the PV LOGTUNER program to see my Log files...more info later...thanks all....
#2326
Under what conditions? The lower figure sounds okay for highway riding, and I wouldn't worry about 270° in slower moving situations, e.g. city streets. I run about 220° highway in 80° weather, higher in city riding. How high depending on how fast the traffic is moving, how often you're sitting at idle, etc.
You'll need to make a note of where the log files are being saved, as those missing files are probably on the computer somewhere. In WinPV > Setup > Options you can designate default folders. When you access these once in PV Tune it will remember the last folder you visited.
#2327
I'm new to Power Vision, but have been reading this thread and several others for the past week. Got my new exhaust and intake installed last night. Then attached the PV and loaded the tune supplied by Fuel Moto.
First of all, the bike runs like a champ!!! Very smooth from zero throttle all the way up to WOT. No decel popping. No hesitation So I don't expect to do much tuning right away.
However, when I open WinPV I am not seeing the same values as the manual shows. Why would I be missing these values.
Thanks
Steve
Thanks
Steve
#2328
#2329
Thanks. This thread has been a wealth of information! It's one of the reasons (besides Moto Fuel's recommendation) that I went with the Vision.
#2330
Thanks...the temps I stated are what I am seeing from slow speeds in stop and go traffic (highest temps) to 70 mph hiway speeds (lowest temps).....the engine does seem to cool down reasonably fast when going from city to hiway.......rode home from work about 3 AM this morning with temp about 65F...engine temp topped out at 209 after about 10 miles and fluctuated between 207-209......went up to about 214 after I hit the side roads.......as far as the Log Tuner goes,I havnt played with it in a couple weeks but I think I recall the program asking for a log file with a different extension than what I am getting from my PV.....maybe I will have time to play with it some more in the near future.....just got off a 43 day stretch at work so havnt had much much 'play time' lately....
