Power Vision Information Thread
#1941
Another question....are my Air-Fuel Ratio (Lambda) numbers supposed to change at all after I run the Log Tuner and save a new tune or do they just stay the same unless I manually change the cells? I've got 14.6 in the 20KPa row and wonder if I should lower that number manually? Oh, and the DynoJet tech said it didn't matter if the numbers were 14.6 or 14.7 because it will still run in closed loop.
I have mine set at 14.0 at 20kpa from 2500 on down, which is where I had some popping. I'm still getting some transient pop, like one pop immediately after pushing the throttle back when hot, and that requires changing DE values for the pertinent temperature.
I would make your AFR changes and continue to tune, as it will pick-up from the point where you made the changes. I wouldn't make a habit of changing AFR values until the tune is consummated, as once that's done you can go in and change the AFR values at will without doing any further tuning--in theory anyway. This works on my '07 and it amazes me how I can tune for 14.5 in a region, come back later to reset at 13.0, and find that it actually does run 13.0 from then on.
#1942
No. Just changed the value file. I had a good collection run that I wanted to use. If log tuner doesn't see .980 or higher in the value file, it won't use values in the log file.
#1943
#1944
From what i've read it says the AFR setting needs to be at 14.6 AFR in order to work in closed loop. If you go into the Air fuel table and type in 14.6 then then uncheck then AFR box top right so the table shows Lambda the cell you changed to 14.6 will read .981 lambda so that is what I am basing my statement on. I did 3 log runs today and couldn't get it to work so what the hell do I know anyway.
#1945
I would make your AFR changes and continue to tune, as it will pick-up from the point where you made the changes. I wouldn't make a habit of changing AFR values until the tune is consummated, as once that's done you can go in and change the AFR values at will without doing any further tuning--in theory anyway. This works on my '07 and it amazes me how I can tune for 14.6 in a region, come back later to reset at 13.0, and find that it actually does run 13.0 from then on.
![Icon Dopey](https://www.hdforums.com/forum/images/smilies/icon_dopey.gif)
#1946
Is this something that you need to do on just the 2012 year bikes or is it something we all have to do?
#1947
#1948
Alright guys i have a question: I have run over 20 data logging sessions on all types of roads and ridding conditions. My VE tables will change by a few numbers up or down each time data log. I am still experiencing some decel popping ( i have the fuel moto pro touring pipes). These pipes may always have a little popping because it's always been there. Also, my bike just doesnt seem to have the power it should, kinda like its being held back or maybe in a strong head wind but no wind. My question is, should i just contact fuelmoto and get a new map to start over with that is setup differently? I am learing the power vision but i am very ignorant when it comes to changing values on my own. I just data log, calculate tune and apply. Thanks very much for the help!
If I run a few logging runs will this affect the changes Jamie made to my tune? It's running very good just needs a little smoothing out. Thanks
UPDATE: Sent my tune off to Jamie at Fuelmoto and 15 minutes later he sent me back a revised tune. He adjusted the decel area, timing and throttle blade. The bike runs great now. Decel popping is almost completely gone and the bike seems to be more responsive.
#1949
So are the AFR settings in WinPV used by the ECM or are the AFR settings only used by log tuner? I mean, if I have a lot of my AFR cells set to 14.6 now while I do logs, do I need to change the cells to some other setting when I get the bike running good?
And how do I know which ones i need to set to something like 13.0? Sorry, I just don't get it. But on a good note, it seems like after doing about eight log runs, my scoot is running smoother and only a rare pop now and then.![Icon Dopey](https://www.hdforums.com/forum/images/smilies/icon_dopey.gif)
#1950
I placed my order for the Power Vision 2 from Fuel Moto for my 2011 Fatboy. i have dealt with Fuel Moto in the past and am always happy with their customer support, so I figured this was my best option. I wanted the TTS Mastertune but I couldn't wait any longer for it to come out. I should get it within the next couple of days. I will post when I get it and how it was to install and use.
