Power Vision Information Thread
#1641
I have been using the 319245 code and it is a big help. One other question, how will i know when the tuning is at the optimal levels? The only changes being made each time are to the VE tables. Will these stop adjusting once at the optimal levels? I am on my 4th tuned map. Thanks so much for the info.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#1642
Thanks, I will probably do a few more tuning runs and just leave it alone. The bike runs very well. It does have some decel popping but that is getting worked out. I am ignorant (but learning) when it comes to all this tuning. I start a log run, ride the bike as suggested by FM and JD and stop the log when I get to my destination. I run another log for my ride home. I then combine and choose both logs when uploading by holding down the Ctrl key. The largest area of difference I see when comparing the old map and the new map I just created is the VE tables. A good bit of the boxes change value by a few #'s some will change from for example 87 to 90, some will go down by a few #'s and others only move a point or two. I am not sure if I should be looking at another value when comparing? Sorry to be long winded. Thanks again!!
#1643
#1645
I just got my power vision just before the holidays. Since I live were there is cold and snow I really have not had a chance to really getting any good tune logs. Ran a few to try to figure out the PV and still learning. So I have been trying to pick up any info on this thread before I start riding again when the weather breaks. I wanted to know what is the 319245 code that you selected. And I put in the tune that Dynojet has on their web page, is there a big difference in the tune that Fuel Moto has. When the weather breaks I am going to try a tune from Fuel Moto, just wanted to know before I start.
#1646
one of your home screens on the pv has a box that says 'enter code'. if you type that code in, it automatically selects the fields that you need in order to do a proper datalog. you don't have to go in and select/deselect the channels you want to log, it does it for you.
#1647
It will set up all the channels you need to log plus give you a screen that shows which cells you are hitting in the map as you ride. Don't forget to start the log on that screen and you should be logging all the data you need.
