Power Vision Information Thread
#1252
Agreed. If you ride at 65mph on the highway then your approach to eco-tuning between 2k and 2500 makes good sense. I typically ride at 70-80mph on the highway and 6th gear is right around 2700 in the low 70's. I usually have several long trips (1000miles +) a year and I'd like to have a "long-distance eco map" for these trips already loaded in the PV.
I break 100ftlbs at 2200 (I'm above 110ftlbs between 2700-5400rpms)...
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
#1253
Heatwave thanks for the Lambda reference.
Whittlebeast I think you have convinced me to try that software now I can not wait to have some time to do it.
I am one ride away from saying the heck with all the gauges I am real close to done worrying about temps, oil pressure, RPM, volts. My 98 wide glide all I ever did was ride and enjoy the ride. This street glide all I do is watch the freakin gauges and worry. I just need to finish up a good tune and ride the snot out of this thing. LOL then I am going to change it to a 107 ci. start all over again.
#1255
Do you use your "eco map" most of the time? I also have a richer map tuned to about 13.5 in the cruise range for those times when I might need some emergency cooling. Unfortunately moving from one to the other isn't as easy as it was with the PCV, which would allow switching between maps on the fly. I miss that, but this bike rarely gets into a worrisome ET range, so I think this richer tune may never be used anyway.
That's fair-to-middlin'.![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
I've only recently developed the Eco map and I'm far from done so I don't have that much experience with it yet.
So what do you consider "middlin-to-good" Torque? What does your current bike have? Nice to benchmark with others.
#1256
#1257
Here is a comparison chart of the front VEs after 7 tuning runs. The left is stock O2 tuning, the right is AT-100 Wideband tuning. Same bike, same starting base map. Interesting..... (updated the comparison with the chart after 7 runs, earlier was after quite a few more.. I really tune too much
![Icon Smile](https://www.hdforums.com/forum/images/smilies/icon_smile.gif)
#1258
I was playing around with the Megalog viewer and began comparing my stock O2 sensor tuning with the wideband AT-100 tuning I did. Not saying this is absolute proof of anything but the results are interesting. While I think both stock O2 and WB tuning work well, I had given the edge to WB tuning based on my "seat-of-the-pants" dyno.
Here is a comparison chart of the front VEs after 7 tuning runs. The left is stock O2 tuning, the right is AT-100 Wideband tuning. Interesting.....
![](http://webpages.charter.net/dgarner02/PV/VEO2vsWB.JPG)
Now, if someone would only make an affordable 12mm O2 sensor for my 12mm bungs since that's the size of my stock NB sensors.
#1259
DynoJet just posted a new version of the tunes database - 0.0.9.6.
It now includes Dynojet Pre-Configured Tunes for 2012 Sportster and Touring Models. It’s available now via the Power Vision Update Client.
http://www.dynojet.com/Blog/index.ph...er-now-posted/
#1260
