Best TunerS
#41
Yes it can take quite a few dyno pulls to make sure no decebel pop on deceleration and get peak performance. Some shops may let you watch the tuner guy work. I didn't know nothing about tuning so i had my bike tuned at the dealership. it run flawless. I feel like a dyno is a must have to get the most out of the bike.
I come from a long way I had a yamaha wr450(liquid) then a kawasaki 750 ltd (air)so ...
#42
tuners
I'll probably try it out first and do my best then if it is hopeless I'll turn it in. I don't necessary seek out the perfection, I want it to be richer, cooler and defenitively more sound. If I can accomplish this by my self without harming the bike I'll be happy
#43
#44
you may be able to try fuelmoto.com for a tuner. they have some cheaper tuners and you just turn a few ***** the turner to richen the bike. Plus you call them an tell them your mods and they can suggest how to set the tuner up. That would be a cheap way to go and save quite a bit of money over some of the more expensive tuners. If you use some of the more expensesive even with the auto tune, you still mat have to have it tweaked on a dyno. that could run over 1,000 bucks just to get it running right. I ain't trying to make any other forum members mad over this post. But the way the economy is a man wants as much as he can get for his money. Just ask if you want to know any more. Thanks for reading my post.
#45
I am currently using the sepst on my bike. I have a new DX and it runs flawless with this tuner. I did have it done at the dealership on a dyno. I also have an 11 Wideglide with the same tuner and had it done at the same dealer by the same tech guy. The DX has topless airbox with SE filter, V&H competition series 2-1 exhaust, SE stage 2 cams. This bike pulled 128hp/88tq at the ground. The 11 Wideglide has SE heavy breather, V&H big radius exhaust. This bike pulled 88hp/95tq at the ground. Both bikes run flawless and I couldn't be happier with both bikes. Some of the tuners you are considering are married to one bike. I had to get 2 sepst for these bikes because they are married to the bikes. They will only work with these bikes. You may want to research a lttle more if you want to tune more than one bike. Some tuners are married to the bike you are tuning and will not work on another bike.
#47
You can go with about any tuner you want with stage 1. You just have to remember that HD sets their bikes pretty lean from the factory. When you do the stage 1 mod, you are just adding more air thus making the bike more lean. This can be damaging to the engine if a tuner isn't added to add more fuel to the system. After more fuel is added, the bike will pick up more power and will probably run cooler than before. You may lose mileage per gallon. Shop around and find a good deal on a tuner. You can tune the bike yourself with a tuner map from the manufacturer of the tuner. You can pay a little more money and get a tuner with the autotune feature. It will tune the bike by itself and you won't have to do much more than plug it in to the bike.
#48
I can get the tts mastertune for 420$ with usb cable and software
or the SEPST 480$ with usb cable software and tutorial software ... (Price are with shipping)
If i'm right .. with the tts it voids the warrenty right ?
So I may revive the thread and repeat myself a little but, I want some more advise ...
And if you got better deals let me know
Thanks all
#49
So basically that's where I stand right now ...
Thanks all
Thanks all
#50
If done with the TTS no one will know you bike has been tuned. You have the ability to change the cal id of the new map to match the one that was in your bike. It also does not "trip" the switch that says you bike has had another map installed. $60 cheaper, easier to use and great tech support= no brainer.
