License Plate Lighting
RE: License Plate Lighting
You tap into the running light lead on the tail light. It is the wire that has 12v + present all the time. The other + wire is brake, black = ground.
No worry about water, 12v DC is harmless at low current and it is all fused. Just tape up the exposed wires well.
Your brake light has 3 wires...
Black - Ground
Red w/ Yellow tracer - Brake power
Blue - Tail light power/Running light..... This is your hot....
Follow this back to the bigger plug that is on the side of the circuit board... Find the blue wire in that harness, and tap in to this wire inbetween the fender plug and the circuit board plug.....
Don't electrical tape it....
Solder and heat shrink is the best way to prevent corrosion and breakage.....
Black - Ground
raptoid780
07-28-2013 06:33 PM
voudoujoe
06-30-2011 07:22 AM
