1996 EFI diag scan tool
If you hooked everything as I described on that 4 prong plug and the test light doesn't start blinking,something is seriously wrong. As you look at that connector attached to your bike,pin 3 and 4 is to the left,1 and 2 to the right. Try again.
thx for everyone's help, especially MikeT. By shorting pins 1-RX receive data from ECM and 2-ground (in the DTC connector pin 1 is bottom left and pin 2 is top left looking at it with the connector lock on the bottom) and measuring across pin 3 (top right)-TX transmit data from ECM and pin 4 (bottom right)-12v from fuel pump relay I was able to pull codes. I unhooked the battery for an hour to purge any old codes and them hooked it back up to read the new codes. 11 and 12. I still do not know what the problem is, but am checking the voltages across each of the sensors to determine whether it's a sensor or wiring issue.
MasterGunz1775
05-09-2017 07:21 AM
