SEPro/SEStreet Tuner Information Thread
Old 06-27-2011, 07:22 AM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
Originally Posted by 02fx4dude
I get slight popping when I'm up shifting, unless I'm really grandpa'ing it. Could be sloppy shifting. Any hints on how to fix that?
Use your DE table. Try reducing the number first. The bigger the number, the more fuel removed. Your AE & DE tables are used for transitional fueling. The left hand side of your afr or lambda table is "usually" used to deal with popping while decelerating.
  #492
Old 06-27-2011, 08:00 AM
atrox88's Avatar
atrox88
atrox88 is offline
Man this thread has been useful. I have finally gotten through the basics and now have a map loaded (although the wrong one) and itsc all starting to make sense.
Can't wait to get the time to load the correct map and start tuning. Thanks for all the help.
  #493
Old 06-27-2011, 09:36 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
Yeah this has been fun. The only problem is, I may get a ticket one of these days
  #494
Old 06-27-2011, 12:15 PM
kevinb62's Avatar
kevinb62
kevinb62 is offline
Can anyone tell me what to expect in h.p. and torque gain after the install of the SE tuner on a 2011 ultra 103ci, stage 1 air cleaner, V&H true duals and 4" round slip on's. A friend just had his done and the dyno numbers the dealer gave him really didn't impress me at all.
  #495
Old 06-27-2011, 05:05 PM
Billyram's Avatar
Billyram
Billyram is offline
One thing is you don't have to be in a big hurry to tune your bike. Make a change and drive it for a while and don't be afraid to make changes. " Anything can be changed back if you don't like it." The VCI can hold up to an hour of data so the more riding under differant conditions will load more cells. 15 or 20 mins of varied driving should load a few cells. To load more cells you need to drive at higher throttle positions where you don't normally drive. Be carefull.
Billy
  #496
Old 06-27-2011, 06:54 PM
02fx4dude's Avatar
02fx4dude
02fx4dude is offline
cool, three different ways to tackle the decel popping... Looks like I'll have plenty to do, and thanks for all the tips. I probably won't get much tuning time until the weekend but will be riding to work all week so I'll be paying attention to how it's running. Thanks for all the suggestion, don't worry , I'll be back.
Billy
Are you sure it can hold an hour of data? I thought I read somewhere it was max 15 minutes. an hour would be great.
  #497
Old 06-27-2011, 08:22 PM
PistonPuller
The book says 15. But I have been able to run a lot longer on a few occasions. I did 2 runs today, went out for about 30min to a buddy's shop. Then stopped the data collecting. Then started it again and came home. When I hooked to the computer it saved 2 data runs.
  #498
Old 06-27-2011, 08:35 PM
Guitar4Him's Avatar
Guitar4Him
Guitar4Him is offline
What's the trick to being able to record multiple data runs while out? I know you have to press the button when collecting data, before shutting the bike off to avoid losing data. Once you've pressed the button to stop recording, can you shut the bike off and then, later, crank it up and be back in record mode again or do you have to connect a PC back up to it to start recording again?
  #499
Old 06-27-2011, 08:39 PM
PistonPuller
Well I sort of stumbled upon it by accident. What I did was pressed the button before shutting off the bike.Then when I went to leave my buddy's shop I noticed that when I turned on the ignition and put the bike in run that the light was lit on the vci. So I pressed the button and it started blinking. OK I figured we will see. When I got home I stopped the vci again before shutting the bike down, then when I downloaded data it ended up saving 2 recordings
  #500
Old 06-27-2011, 09:29 PM
poppavein's Avatar
poppavein
poppavein is offline
Yep, you will be in record mode until you hook it up to the PC again and take it out of that mode.
You can store several data runs while you are out riding; push the button to start recording a new run and push it again to stop. This way you can separate your WFO runs from the 5mph increment runs, for example.
Quick Reply: SEPro/SEStreet Tuner Information Thread
