SEPro/SEStreet Tuner Information Thread
#3901
#3903
HELP.........04 heritage FLSTCI fuel injected,,,I think i fried my PCM , while putting in a new MAP, with my SE Super Pro Tuner,, yes the orange one,,, my battery dropped below 10V,, now there is no communication ,, and tuner has lost the VIN #, all values are zero,, bike is now no start,,, question?? is the PCM married to the VIN, can i put in a used PCM ... Do I just take it to the dealer for reflash,,with my VIN,, 500 km away, on a trailer ,,, or add on dynatek. or ??? i can't be the only one this has happened too. , I hate having a dead bike,, any other ideas that would be helpful are appreciated,,,, The PCM is on backorder throughout north america
Thank You My Brothers
#3904
let me know if the link works
https://drive.google.com/file/d/1ITs...w?usp=drivesdk
thank you very much 👍
Rollbar (10-04-2023)
#3905
Received 12,629 Likes
You need to have Google Drive installed on your computer. Once you do that, you may need to sign-in to the Google Drive app. Then you should be able to open the file link provided by Jordan1200.
#3906
I found a lot of confusion in the forums between the Screaming Eagle Super Tuner Pro - Orange Tuning Module (VCI) and the Screaming Eagle Pro Street Tuner - Black Tuning Module (VCI).
SESTP - Orange vs. SEPST - Black. The older Orange module was discontinued because it allowed tuning outside of EPA regs. The newer Black Tuner is EPA compliant.
screaming eagle super tuner pro - Search Images (bing.com)
Screamin' Eagle Pro Street Tuner 41000008C | Harley-Davidson USA
I'll add this info here because I had a hard time finding it.
This is a link to the H-D Screaming Eagle Pro Street Tuner (Black) training program.
I believe it is very similar to the original training program for the Screaming Eagle Super Tuner Pro (Orange).
streetperformancetuner.harley-davidson.com/training/ENU/index.html
This is a link to the Screaming Eagle Super Tuner Pro computer software needed for tuning.
You will need Google Drive setup on your computer in order for it to download. I had trouble getting the download but, I finally figured it out.
https://redirect.viglink.com/?format...usp%3Ddrivesdk
joenc (03-07-2024)
#3907
Is the SE Pro Street Tuner enough for what I am doing to my trike? I know this has been talked about a lot, but I'm not sure. I have a 22 CVO Tri Glide. Had the dealer put Rinehart slip ons on it before it left the dealership. The only other performance mod I am planning is to put the Cobra Pro Chamber head pipes on it. They are basically a 2-1-2 and eliminate the cat. I have the SE Pro Street Tuner. Do I need to use it when I change the head pipes? If so, will a couple of tuning runs be enough. Thanks.
#3910
