SEPro/SEStreet Tuner Information Thread
Old 03-03-2022, 04:25 AM
Pinnacle's Avatar
Pinnacle
Pinnacle is offline
I have a 2019 Street bob With SE street tuner I just picked up from Harley. Its my understanding that this is useless at tuning VE tables an tIming?
My question,is it possible to get SE Super pro tuner to allow full access to tables/tune and adjustability?
That would be comparable with my bike?
  #3702
Old 03-03-2022, 07:56 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Veteran: ArmyVeteran: Navy
Received 6,596 Likes on 1,817 Posts
Not useless, but in order to meet CARB/EPA/DOT requirements, means limited adjustments (+/- 4% cruise/idle areas, +/- 10% WOT). If you use only SE stage 1/2 components, and the street tuner has a map for the combo, it will be adequate. Aftermarket (non EPA legal) Stage 1 (non-cat pipes/hi flow AC), FP3 is adequate. If you want to modify beyond that, get a TTS or Power Vision tuner, consult with a local tuner for device preference.
There are no SE Super Tuner maps available for the 2019 models.
Pinnacle (03-03-2022)
  #3703
Old 03-03-2022, 08:06 AM
Pinnacle's Avatar
Pinnacle
Pinnacle is offline
Couldn't I Use the 2018 maps? since those are available?
I found a good deal on an orange tuner not married im wondering if I should get it.
I live in California so getting a tuner not easy.
  #3704
Old 03-03-2022, 10:24 AM
rigidthumper
The software looks at the VIN, specifically the 10th digit to determine year. Since the Super Tuner was eliminated post EPA agreement, and the program terminated post 2018 model year, it may not even recognize the 2019 VIN as valid. You're welcome to speculate, but because the 2018 ECM part number (41000668) is different from the 2019 (41000599) part number, I do not believe it will work.
Pinnacle (03-04-2022)
  #3705
Old 03-03-2022, 10:32 AM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,540 Likes on 932 Posts
I will have a black 41000008c tuner unmarried with the 6 pin cable available next week if your interested.
  #3706
Old 03-04-2022, 12:15 AM
HDkazHD's Avatar
HDkazHD
HDkazHD is offline
Default Record function
Originally Posted by rigidthumper
Hook the VCI to the cables, plug the bike side in, and PC side in. Put the VCI in record mode. (Not smart tune, as this mode retards timing and leans the AFR out)
Disconnect the VCI-PC cable from the VCI, and stash the VCI in the saddlebag, still hooked up to the bike. Take a short ride to get the bike up to operating temp. Pull over someplace safe, & open bag, and press the red button on the VCI to start recording. Secure the VCI back in the bag, and take a typical ride, hitting cruise below 60, and cruise above 60. When you get back, hit the red button to stop recording, reconnect the VCI-PC cable, download the recorded data file, then turn the bike off. Open/review the data to see if there is significant engine temp changes above/below 60, or if it's an air movement across your legs phenomenon. If you need help interpreting data, you can post the file here.
After downloaded the recorded data, do I need to do anything to set back to normal function?
  #3707
Old 03-04-2022, 07:49 AM
rigidthumper
No, all it will do is record. Once the data is retrieved from the VCI, you can flash, or record more data, as needed.
  #3708
Old 03-14-2022, 08:09 PM
Barndog107's Avatar
Barndog107
Barndog107 is offline
6th Gear
Hopefully someone can help me out, Details: 2021 FLTRX, SEPST 41000008c I have downloaded the SE pro street tuner software, Done the Driver dance to get the correct driver. Now when I plug into the bike it gives me the error message "Incorrect VCI connected. Anyone have any idea what is next.
  #3709
Old 03-14-2022, 08:58 PM
Slingshot383's Avatar
Slingshot383
Slingshot383 is offline
Instead of the bikes serial number, put in all 1's and try again.
  #3710
Old 03-14-2022, 10:19 PM
Barndog107's Avatar
Barndog107
6th Gear
reloaded software, entered all 1’s. Red light came on finally on the VCI. No communication with computer. Reset the cables and cycled the ignition and run switch. Red light went out and incorrect vci message came back
Quick Reply: SEPro/SEStreet Tuner Information Thread
