SEPro/SEStreet Tuner Information Thread
#3621
Haha, I understand that. But any smart dealership wouldn't turn away work. The problem is, HD requested all dealerships to hook up Digital Technician when performing warranty work (at least with engines). If any tuner other than SE is used, DT will pick it up and then flag your VIN. Once flagged, your screwed. As I understand it, SE tuner does not flag the VIN. If this is the case, I want to know if you can use any exhaust combo (not SE) with the SE tuner?
#3622
You can use any muffler you want, but must keep the headpipe with the Catalytic converter in it. You can also use any air cleaner assembly you like. You can also use a complete exhaust system that has Catalytic converters in it, like the Screamin Eagle High Flow system or the S&S system, and the Pro Street Tuner can be used to tune the bike.
#3623
#3625
#3627
Which Se tuner? The street tuner is only good for keeping the EPA compliance. The SE Super tuner is perfectly capable tuner for most applications.
Slingshot383 (09-30-2020)
#3628
Couple of quick questions guys. I have my Pro Street tuner on order and awaiting on it to arrive. First off is the software Windows only or is there a Mac download as well? Second Harley says that the cable kit (41000018) is unavailable. Anyone have the cable kit that they are willing to sell?
Thanks!!
Thanks!!
#3629
