SEPro/SEStreet Tuner Information Thread
Old 06-20-2020 | 08:54 AM
60Gunner's Avatar
60Gunner
The cells in the VE tables you hit will colored.
jordan1200 (06-20-2020)
  #3582
Old 06-20-2020 | 02:30 PM
TrAnc's Avatar
TrAnc
hey
I have done like 10 full test rides till memory was full. But I cannot get any update above 3000rpm , and 40% throttle. Only updates tables between 1000-2750rpm and throttle by 30% . In my opinion I don't see any difference between stock map vs my modified.
  #3583
Old 07-08-2020 | 04:55 PM
stewd8's Avatar
stewd8
Default Learning
Tring to learn about this se pro tuner,, first off,,,i dont have a laptop,,,, can i plug in my tuner to the bike,,, record my ecm,,, then unplug it and take it to my home pc,,, down stairs,,and adjust things,,,then take it back up to bike , and up load,, or do i need the laptop , tuner, and bike all running as one....thanks,,, im sure there will be more questions
  #3584
Old 07-09-2020 | 01:32 PM
rigidthumper's Avatar
rigidthumper
Veteran: ArmyVeteran: Navy
You need vehicle power & ECM connection to upload/download maps and download recorded data into your computer. Laptops are convenient for these functions
  #3585
Old 07-09-2020 | 05:28 PM
stewd8's Avatar
stewd8
So the se pro tuner is not for storage ,,,or will not store a map
  #3586
Old 07-10-2020 | 10:54 AM
rigidthumper
The orange VCIs keep a copy of the last map sent through them, and can record ECM data while riding. What else do you want them to do?
  #3587
Old 07-11-2020 | 12:15 AM
stewd8's Avatar
stewd8
THANKS RIGIDTHUMPER,,,,, I guess I want to plug the orange VCI into my bike,, have it record whats in there,,,un plug it and take it to my home pc,, and have it all right there,, i just want to fatten it,,,richen it one or two notches,,, then plug it back into bike,,and upload it ,,,, i thought that's how they worked,,,,, but now i learn all 3 have to be hooked up at once
  #3588
Old 07-11-2020 | 09:04 AM
rigidthumper
You can do all that, but during transfer (of recorded data, the old map, or the new map), everything has to be plugged in, key on, run/stop switch in the run position. Once the transfer is complete, you can put the VCI in record mode, disconnect the VCI from the computer, and go ride/record data. When you come back, reconnect to the PC/laptop, download the info to the computer, & disconnect from the bike. You can then view the data, and manipulate the map as desired.
  #3589
Old 07-12-2020 | 08:55 AM
garysol1's Avatar
garysol1
Couple of quick questions guys. I have my Pro Street tuner on order and awaiting on it to arrive. First off is the software Windows only or is there a Mac download as well? Second Harley says that the cable kit (41000018) is unavailable. Anyone have the cable kit that they are willing to sell?
Thanks!!
  #3590
Old 07-12-2020 | 02:20 PM
rigidthumper
Windows only.
Cables at the bottom of this page http://www.mastertune.net/products_mastertune.html
garysol1 (07-12-2020)
