SEPro/SEStreet Tuner Information Thread
Old 06-16-2020, 09:51 AM
Sparky357's Avatar
Sparky357
Sparky357 is offline
Originally Posted by pfbmgd
I have 20 with S&S slip ons . I find the bike runs real hot . I would like to install a K&N filter on the bike , What tuner will Harley make me buy to keep my warranty ? Will the tuner from Harley solve the heat issue and running lean ?
The tuner they'll make you buy is theirs and get used to the heat as long as you're using the Screamin Eagle tuner.
  #3572
Old 06-16-2020, 12:21 PM
jordan1200's Avatar
jordan1200
jordan1200 is offline
Default Best way to reflash stage 1 tune and start over from there?
I want to start my tuning over again with the base stage 1 tune file. I did a few street tunes so i want to know the best way to start again clearing out old data and starting over fresh. I want the tuner clean of of session data as well as the PC software.
what is the best way to do this and is there a reason i shouldn't?
Thanks everyone
  #3573
Old 06-17-2020, 04:41 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Just load the stage 1 calibration you started with. Simple as that.
  #3574
Old 06-17-2020, 05:28 AM
jordan1200's Avatar
jordan1200
what about the saved calibrations in the software. Also, isn't there some data logging information taking up space in the street tuner?
  #3575
Old 06-17-2020, 11:22 AM
Slingshot383's Avatar
Slingshot383
Slingshot383 is offline
Those are files saved to a folder on your computer, not in your way at all.
  #3576
Old 06-17-2020, 11:29 AM
jordan1200's Avatar
jordan1200
so the info save to the tuner during a street tune is not still on the device itself?
The reason i wanted to remove old files onthe PC is to avoid confusion for myself moving forward.
  #3577
Old 06-18-2020, 11:20 AM
Slingshot383
When you finish a record run and dump it to the computer, that is where it is. That way, you make your corrections to your tune, upload the "new" tune to the bike, do some more record runs and do the process over again, Since it only records about 15 minutes of data, it takes a lot of record runs to make a complete tune. It takes 10 sec. to record a spot (rpm X load) and you need to do it for every 100 or 250 rpm segment and multiple gears to get a great tune.
  #3578
Old 06-18-2020, 11:43 AM
jordan1200's Avatar
jordan1200
ok sounds good, how can i tell when i have hit as many cells as possible with the tuning sessions?
  #3579
Old 06-19-2020, 11:48 AM
Slingshot383
While you are riding, it would be hard to do unless you put tape around the throttle and put hash marks on the tape, and hold each division for 10 sec. before going to the next, do it in 2nd gear, and again in 4th gear. Once your done and download to the computer, you'll see which cells took, and which ones you need to hit still.
  #3580
Old 06-19-2020, 12:20 PM
jordan1200's Avatar
jordan1200
thanks for the response. I actually meant how cani tell on the computer.
Quick Reply: SEPro/SEStreet Tuner Information Thread
