SEPro/SEStreet Tuner Information Thread
Old 07-24-2018, 11:01 AM
harleytuner's Avatar
harleytuner
harleytuner is offline
Originally Posted by HD69HEAD
So I am considering the SE smart Tune 41000445 is the part number . I will be installing a stage IV and 4" bore on the bike which is a 2014 Ultra Limited 103"
Can anyone enlighten me on the pros ? AND cons?
That's an add on feature for the SE Street tuner. I personally wouldn't go this route, the Street tuner is pretty limited is adjustability, You will be stuck with US EPA compliant MAPs to run and more than likely the bike will be to lean when you are finished. TTS Mastertune #2000012 allows you to use wide band o2 sensors and you can self tune with it if you want and you will have closer base MAPs to start with.
  #3492
Old 07-24-2018, 11:36 AM
Sparky357's Avatar
Sparky357
Sparky357 is offline
On your year bike I would completely skip Screamin Eagle tuner and get a real one it’s a joke . TTS,Power Vision or Fuelpak will do you much better with those mods.
  #3493
Old 07-25-2018, 10:54 AM
HD69HEAD's Avatar
HD69HEAD
HD69HEAD is offline
I have been looking at Fuel pak and SE Pro that has the O2 sensors . It claims to be self tuning to the rider . Would really like to hear from experience on Both the SE pro And Fuel Pak ?
  #3494
Old 07-26-2018, 05:36 AM
Slingshot383's Avatar
Slingshot383
Slingshot383 is offline
Because of the settlement with the EPA, Harley can only sell the Street Tuner anymore in the US. You can still get the Screamin Eagle Pro Super Tuner from Canada, Austria, and Australia.The Pro Super Tuner is a very good tuner and for any Harley 2016 and older will not mess with the warranty.
  #3495
Old 07-26-2018, 06:37 AM
badcooky's Avatar
badcooky
badcooky is offline
I think we ran out man, HD shops are now buying the TTS Mastertune to tune bikes with warranty.
For real.
Slingshot383 (07-27-2018)
  #3496
Old 07-26-2018, 06:59 AM
harleytuner
I believe HD said they wouldn't sell the super tuner in all of North America. Maybe i'm mistaken.
  #3497
Old 07-26-2018, 07:05 AM
harleytuner
SE Pro will keep everything in EPA parameters. It will not allow adjustment outside of these ranges. You will have limited access to tables. FP3 can get a stage 1 build running halfway decent but but that's about it. If you ever decide to go to a dyno shop you'd be hard pressed to find a tuner that will use it. For anything more than a simple stage 1 I highly recommend a either a TTS or the Power Vision. Either one will get the job done, TTS has a much better selection of base MAPs to start with.
  #3498
Old 07-28-2018, 04:35 PM
HD69HEAD's Avatar
HD69HEAD
HD69HEAD is offline
Ok been researching the TTS . I'm not sold . The Power Vision maybe . Anyone else had experience with these 2 ?"
  #3499
Old 07-29-2018, 09:57 AM
Slingshot383
#1 There is a big difference between the Street Tuner, and the Pro Super Tuner. #2 the Pro Super Tuner and the TTS Tuner are very similar as they were both developed by the same person. #4 The Pro Super Tuner and the TTS can use each others software (to a point), both can trim both fuel tables and ignition timing.
  #3500
Old 07-29-2018, 10:35 AM
Fullbore55's Avatar
Fullbore55
Fullbore55 is offline
Received 2,730 Likes on 1,264 Posts
I already have SE Street Tuner for M8Stage 2. With a couple of “auto tunes” I’m confident it doesnt run too lean.
If I decat stock header, can it be adequately re-tuned with Street Tuner?
Quick Reply: SEPro/SEStreet Tuner Information Thread
