SEPro/SEStreet Tuner Information Thread
Old 07-12-2015, 12:08 PM
paud's Avatar
paud
paud is offline
Default ping-ing
I have used SEPro many times but have run into a dilemma.
I ran a few smart tunes because I heard some pining. Corrected VE and then move timing just a bit.
Now I have a ping on acceleration.
Here is the delema: When in smart tune I do not hear nor notice the ping.
WHen I recorded with out smart tune I saw where the ping was, but there was also some acceleration gas coming in.
Could I use the data I recorded without smart tune to correct timing?
  #3102
Old 07-12-2015, 07:58 PM
1Canuck's Avatar
1Canuck
1Canuck is offline
Received 2,252 Likes on 1,439 Posts
if the data does not show a ping then how could you use it?
do a data run without smartune and if you do get ping live it will be recorded as well. smartune setting retards timing 4* BTW
  #3103
Old 07-12-2015, 10:17 PM
paud's Avatar
paud
paud is offline
Well, yeah. My point being that if i am recording and it is not smart tune and I see a ping AND at that ping data shows accel enrichment, do i go to ve first, or timing first.
  #3104
Old 07-12-2015, 10:33 PM
1Canuck's Avatar
1Canuck
1Canuck is offline
identify the frame for timing cell that is involved in the knock retard F or R. then what cell just before. go to timing and retard a couple degrees and do another data run.
(finding it hard to put into words)
compare timing in those cells and if it is where you advanced then you are on right track.
  #3105
Old 07-13-2015, 11:40 AM
paud's Avatar
paud
paud is offline
I understand. I just was not sure if the accel enrichment would throw things off.
  #3106
Old 07-13-2015, 02:47 PM
1Canuck's Avatar
1Canuck
1Canuck is offline
AE will affect VE & ping. when smartuning it adds fuel and expected air will be wrong. a ping that may have occurred due to a lean condition may be masked. IMO not a big concern for finding/fixing your problem. usually the point where ping is reported is already several frames past when it occurred as it is a response to a knock, not the actual time of the knock
  #3107
Old 07-13-2015, 07:43 PM
Donk kinney's Avatar
Donk kinney
Donk kinney is offline
Stage IV
I have a tuning problem I have a 2014 breakout Vance and Hines short shots and a heavy breather with the screaming Eagle supertuner. And my pipes crackle and pop extremely on deceleration and when I let off the throttleas aswell as shift gears. I know with the Vance and Hines short shots this happens a little bit but not extreme like it is now. I just need to know if I need more fuel more air or if I'm to rich already. I took at the Harley-Davidson and they adjusted my fuel it helped a little bit but not as much as it should
  #3108
Old 07-15-2015, 02:05 PM
paud's Avatar
paud
paud is offline
Did a half hour run today, recorded NOT using 'Smart Tune". Heard pinging when hard on the throttle, wide open. Downloaded recording and....NO knock retard incidences. Oh Well.
  #3109
Old 07-15-2015, 03:12 PM
1Canuck's Avatar
1Canuck
1Canuck is offline
Then you are hearing something other than knock/ping
  #3110
Old 07-16-2015, 07:55 AM
Sam D.'s Avatar
Sam D.
Sam D. is offline
I was having a rattling (like a ping) sound when pulling away from stops when fully hot now that the outside temps are up in upper 80's ... Lowered my AF setting to 10% Ethanol Grade Gas and it stopped it.
Quick Reply: SEPro/SEStreet Tuner Information Thread
