SEPro/SEStreet Tuner Information Thread
Old 12-29-2013 | 11:01 AM
Foxster's Avatar
Foxster
Originally Posted by thevirginian
I have another question for you, guys. I have done three tuning runs, so far. Downloaded the files as described by you experts. Everything went smooth, no glitches, or hick-ups. One thing I just noticed, that makes me wonder. I loaded the base calibration (176AE106), which I used to flash my ECM with, before the smart tuning process and opened the A/F Ratio table. Then I opened the saved file from my last tuning run and opened the A/F Ratio table for comparison. To my surprise, both tables are identical. Am I missing something here, or did I screw up? Also, how do I turn on the smart tune check box before a recording run? Both boxes are greyed out, unless I re-flash the ECM with the latest file and, before closing that window, check the boxes. I am a little confused. Your help is greatly appreciated
I hope I'm answering just what you are asking...
Smart tune doesn't change the AFR table, it only makes changes to the VE tables.
You can only set Smart tune on by flashing the ECM. This can be the same file you have been using or a new one but it has to be flashed to the ECM with Smart Tune checked to put the ECM into Smart Tune data collection mode.
  #2302
Old 12-29-2013 | 11:22 AM
1Canuck's Avatar
1Canuck
As Foxster said, the AFR is not changed with smartune, the VE is changed. so if you did a smartune data run, then opened the smartune and loaded the data run, then you pressed update, it will update the VE only.
Now if you go to the re flash page and see the smartune and reset AFV greyed out it will be because you have not yet saved the updated VE in the previous step. save it to a new file name each time so you can go back (if you want) to see what changes were made.
again the Smartune and AFV is greyed out if you try to flash before saving the updated file.
  #2303
Old 12-29-2013 | 01:12 PM
ILLADELPHFATBOY's Avatar
ILLADELPHFATBOY
Originally Posted by Foxster
176AE106.dt0 is the starting point for all stage-1 BTs. Do a bit of Smart Tuning and it should bed in nicely.
Thank you kindly! That's pretty much what I was after. In retrospect, I suppose my post made my bike out to have serious issues, but in reality it runs fine by most peoples' standards...Just not by MY standards. I know it can be approved upon, and thats my goal.
The fuel puddling up in my breather only happens once in a while, and I feel it's mostly because I'm prone to fill my tank to the tippy top. Upon further review, my inner exhaust tips are showing a bit of black, moist soot, that has a faint fuel smell, coupled with my not so perfect starting condition, I'd venture to say I'm probably running a bit too rich. I guess I will find out soon enough.
Thanks again! I'm sure I will be back with tuning questions in the upcoming weeks...lol. Enjoy the New Year All, and be safe!
  #2304
Old 12-29-2013 | 01:45 PM
editbrain's Avatar
editbrain
My 2010 FXDBi runs at 40-44 MPG. I use Valvoline 20w50 motorcycle oil in the engine and primary, and 75w-140 in the tranny.
I used the SEPST to tune my bike along with the "My Tune" software to adjust the timing. I am running stock cans with Cycle Shack baffles and a SE Air Breather (not the big sucker).
I'd say 25 mpg is running super rich.
  #2305
Old 12-29-2013 | 02:02 PM
thevirginian's Avatar
thevirginian
Foxster, I think I went exactly along your instruction you spelled out so nicely in the H-D-hangout forum. At step 49 you expressed not to check the smart tune box, but only the AFV box. Now, if I want to do another recording run, how do I check the smart tune box, or don't I need this box checked again? I did save all my recording runs after I loaded them into the tuning window and accepted the changes. BTW, my new tables did change with every new recording file loaded. If I want to change decel popping I have to do that manually in the A/F tables, correct?
  #2306
Old 12-30-2013 | 08:18 AM
harleytuner's Avatar
harleytuner
If you want to do another smart tune run in the future, just re-load your current MAP in the bike and check the Enable Smarttune box. Then you are set to do your recording.
  #2307
Old 12-30-2013 | 12:40 PM
thevirginian
harleytuner, I assume you mean my last saved recording run. I did save all of my recording runs after I made the changes and re-flashed the ECM. OK, I will make sure to check the box. If I want to get rid of my decal popping, I guess I have to do these changes manually in the AFR tables, correct?
  #2308
Old 12-31-2013 | 07:59 AM
harleytuner
Yes your last saved recording run is the MAP that is currently in your ECM, so just re-load that one with the box checked. To get rid of decal popping you can do it in either your VE tables or your AFR tables or both.
  #2309
Old 12-31-2013 | 09:34 AM
thevirginian
Thanks harleytuner. Which way would you recommend I should follow to get rid of the decel pop? And what numbers should I change first? In what column should I make changes?
  #2310
Old 12-31-2013 | 10:06 AM
thevirginian
I have another question for harleytuner: In posting 1105 you suggested to paud to try your AFR values you posted. Can I try the same values for my '08 HS, or would they only work for a touring model?
