SEPro/SEStreet Tuner Information Thread
#2062
#2064
What’s New in This Version of Screamin' Eagle Pro Super Tuner.
Version 7.001.0000
Version 7.001.0000 Software is a 2014 Model Year update which includes the following:
Software Information Summary:
Description
Version
Screamin' Eagle Pro Super Tuner Software Version
7.001.0000
Calibrations Added:
Year
Configuration
Calibration
2014 Touring
Air Cooled
1962 SE PRO 120
Calibrations Superseded:
Year
Configuration
Calibration
2014 Touring
Air Cooled
1962 SE PRO 120
Version 7.000.0004
Version 7.000.0004 Software is a 2014 Model Year update which includes the following:
Description
Version
7.000.0004
Calibrations Added:
Year
Configuration
Calibration
2014 Touring
Air Cooled
1690 Stage 1
1690 Stage 2 w/259E cams
1690 Stage 3
1690 Stage 4
1800 Stage 1
1800 Stage 2
1962 SE PRO 120
2014 Touring
Twin Cooled
1690 Stage 1 Twin Cooled
1690 Stage 2 Twin Cooled w/259E cams
1690 Stage 4 Twin Cooled
1800 Stage 1 Twin Cooled
1800 Stage 2 Twin Cooled
2014 CVO Softail
1800 Stage 1
2014 XL
883 Stage 1
1200 Stage 1
User Interface:
- Super Tuner software is now resizable using the controls in the upper right corner. (Minimum size is 1024 X 768)
VCI Update:
- This update includes a new VCI software version. You will be required to update your software when you connect for the first time.
Data:
Tuning:
- Smart tune modifications allow the interpolation function to be used for a wider range of cells.
Windows 8 Compatibility:
- Super Tuner is now compatible with Windows 8 (32-bit and 64-bit).
User’s Guide:
- User’s Guide has been merged into the Help File to simplify where technical information is located.
#2065
Okay, new on the board here and have seen some good stuff. Need some help with the SEPST. Have a 2013 FLHTK w/stage 1 kit and Python slash cuts. Seems no matter what I do the engine pings in the 2500 to 3100 RPM range. I have tried to decrease the timing, richen the fuel mix to no avail. Any thoughts would be appreciated. I have run about 7 recordings and updates using the smart tune feature. Thx in advance!
#2066
#2067
https://www.hdforums.com/forum/touri...-resolved.html
#2068
SE Pro Tuner ? SEST
Are you sure that you are not talking about the Screamin Eagle Super Tuner ?
I didn't think that the Smart Tune feature was offered with a Street Tuner. It also appears that the latest update to the Super Tuner has made changes to the smart tune function.
Don't want to derail the discussion on the Street Tuner, so if there is a separate discussion going on for the Super Tuner, please attach a link
#2069
Detonation
Guzz,
Interesting post. I am new to the Forums but not new to the Super Tuner. I also ended up with detonation after building my 2008 Ultra Into a 103 with the 255 cams. After a lot of playing around with Exhausts and Air Cleaners and re running the Smart Tune feature, I decided to have the bike Dyno Tuned at my dealer...big mistake. The only thing that I could see they did was bump up the VE tables by at least 15 percent, which resulted in more detonation. I think that there is a limit to how much fuel you can dump in as more fuel= a larger combustion event and after a certain point you just create a hotter cylinder.
I went back to the base cal from the super tuner menu and guess what...no more pinging.
So now I am back to running the Smart Tune feature, recording the data runs and making changes.
#2070
