SEPro/SEStreet Tuner Information Thread
#1931
#1933
I would like to start a new HD Tuner information thread.
This is to be a thread for the exchange of information concerning the HD tuners. I would like to focus on the SESPT (SEPro) since it is the current generation product and limit discussion on the Street Tuner (SEStreet) since it only allows the dealer to upload street legal calibrations and does not permit DIY tuning.
I would prefer that this become a knowledge base for SEPST users and not a debate about what tuning product is better. Ideally posts would contain user tips, questions on using the tuner and various features, user experiences both successes and failures, etc. perhaps even some tutorial type stuff.
I have been tuning carbureted bikes since I was a teenager. So I have a grasp of the basics. But fast Forward to 2008 and my new EFI Fat Bob. I decided after some research that I wanted a tuner that would allow me to reprogram the ECM and not just an add on. So I purchased the SEPST, Cable Kit, and Software from Zannotti’s and got a great deal.
I soon realized that most of the discussion concerning tuning revolved around the VE tables. Before Smart Tune was added as a feature I would set my AFR table to 14.6 across the board and ride and record data. I would manually adjust the VE table to bring it closer in line with what I was observing from the recorded data. This seemed to be working well, and then I upgraded the Software and was able to Smart Tune. IMHO the bike runs great. Now I am tweaking the timing. My plan is to develop ignition timing tables based on a high degree of advance and compare them on a dyno to the base tables.
Anyone care to share?
Last edited by Smokey Gold; 04-09-2013 at 09:06 AM. Reason: spelling of any ln last sentence
#1934
Does anyone know if the SE Pro Super tuner can be used on multiple bikes. I have the 32109-08 and want to use it in my 2007 and 2009 XLC1200 if possible. If it can be used are there any prerequisits like re-initializing or anything else that will enable it to work on both bikes. Thanks for ant info you can give to me, Smokey Gold
#1935
Ok, since Mverzola and I have been debating this point for some time, and he knows how I hate to admit he is right, which I may have to do here, to keep things very simple for my wine addled brain- If on a lambda based calibration (2012 Touring Bike with latest software) you change the fuel setting from gas to 10% ethanol, essentially it means nothing. As long as you are in closed loop the system will handle it regardless of the fuel. If you want to richen up the mixture, changing to ethanol setting is NOT the way to do it.
Correct?
Correct?
In summary before you admit defeat in your bet, seek out advice from real professionals and not "Professionals". After all the tuner at your local Harley shop calls himself a Professional as well. I am not a Professional motorcycle tuner but I did sleep at a Holiday Inn Express last night. Where I read the manual for the software that I have used multiple times with great success. For those of you who whined that people were "guessing" you should pay me for looking up info you could spend time and find for yourself instead of paying the "best tuner in North America" to not understand what Lambda is.
#1936
#1937
#1938
There ARE two kinds of tuners. Those that work at Dealers, etc and make wages. Then there are those that invested like $30k to start out! Lots more money after that, I assure you. Lonewolf is of the second variety, and I take HUGE exception to your mislableing him as a punk no nothing tuner. Me? I ALSO have invested in a dyno and a small shop. Pretty much R&D work for a cam designer right now. Ummm.. I may NOT know tuning 100% like some pros, but tell you what, I KNOW how an ECM functions quite well.
How many bikes have YOU tuned again?
PS... it DOES appear you DO have a good handle on some of this. Especially the part that at lambda1, it IS a representation and will NOT be the actual value out of the pipe.
#1939
OK, I'm going to start this with the admission that I am in the deep end of the pool and I'm dog paddling, at best. I have a 2011 Road King that has SEPST, D&D Fatcat and SE intake. It was all installed and dyno tuned at the dealer I purchased the bike from. According to the the dyno sheet, the bike made
Stock
HP 62.61
TQ 77.87
After Tuning (work was done at 6956 miles)
HP 77.40
TQ 89.40
According to the chart I got, the AFR is in the 13s. It's hard to tell exactly, my eyes are getting old. But suffice to say, it's clearly below 14. After I got the bike back I noticed I wasn't able to put the bike into ETIMS. I thought it was a little weird but didn't really think much about it. The bike did and does run great. I like the power, throttle response, well everything really. It does have a slight off throttle burble on decel and occasionally will pop between shifts, especially when the air is cooler in the morning. I checked for exhaust leaks and couldn't find any. (used incense sticks)
I'm getting near 50 mpg sometimes and my thought is nothing comes for free. If the mixture is indeed in the 13s; how am I getting such good mileage? Granted, I'm putting around with my wife in tow on her Sportster most of the time and I weigh 160 all up; but fuel mileage that good?
I remember one time after I had the work done that we got stuck on the highway in a traffic jam. The bike went into ETIMS on its own, several times because we weren't moving and it was hot, hot. So my long winded question is:
Is it possible that my bike went back to a stock AFR because ETIMS was engaged?
Can I buy the cable, software and CD to just look at the AFRs?
I know this is kinda buried here but I felt this was the best place to ask as opposed to starting another thread.
Thanks
Stock
HP 62.61
TQ 77.87
HP 77.40
TQ 89.40
Thanks
#1940
If I understand you correctly, you are saying EITMS doesn't operate as much as before? If so, then that is as it should be if it has been tuned away from the stock AFRs; the engine will be running significantly cooler now, that's an effect of a richer tune.
You can buy the cable and software (assuming you have the SEPST and it wasn't left at the dealers) and look at all the settings and what the AFRs are set to.
If the bike is running good and you are getting good MPG then why worry? Chances are you aren't a rider that thrashes around at the redline all the time and so aren't seeing heavy fuel consumption.
