SEPro/SEStreet Tuner Information Thread
#1801
I'm no expert on this and only know what I have learned from using the product but this is my take on it...
When you do a Smartune it sets all the AFR table to 14.6:1 and so all the map is in closed loop and the O2 sensors are working at all the entries in the AFR table. It also sets the VE entries to 100%.
Then when you do the run it reads the O2 sensors for the AFR at each rev/throttle-setting you hit. If the AFR reading is higher than 14.6:1 then it is lean because there is more air flowing through the engine, this means the VE is over 100%. So it adjusts the VE entry at that point by a factor depending on what AFR it read. And the other way for rich readings.
#1802
...Afaik, the calculation the "smart tuning" does is simply to do a statistical analysis on looking through the sample data comparing how many percent the o2 sensor (integrator) output differs from stoich for each cell on average and the new cell value is calculated from the original cell value based on that percentage. As the sensors are narrowband, that analysis is not exact but it in general corrects the ve's to the right direction.
#1803
My guess would be that it's a pretty simple formula. I know on the dyno 1 whole VE number equals approximately .1 A/F. For instance if I have a value of 92.5 in a certain VE cell and I want to richen up the A/F in that cell by .2 (example I read 14.2 A/F and I want 14.0 in that cell) I would change the VE value to 94.5. So that would tell me that Smarttune just does the math.
#1804
The formula for determining volumetric efficiency in a typical combustion engine is to multiply 3456 by the engine air flow rate (measured in cubic feet per minute) and then divide the result by the amount achieved by multiplying the engine size, displacement or volume (measured in cubic inches) by the engine speed (measured in revolutions per minute). For the sake of clarity, the formula for volumetric efficiency in a combustion engine looks like this: 3456 x Cubic Feet Per Minute/Cubic Inch Displacement x Revolutions Per Minute.
Solving For Engine Volumetric Efficiency
cubic feet per minute (CFM)
cubic inch displacement (CID)
revolutions per minute (RPM)
The most common and effective way to enhance volumetric efficiency in an engine is to increase the size or number of valves in the engine. While larger valves increase flow, they can have the negative effect of causing the engine to weigh more. Using multiple valves can increase the flow of an engine without adversely affecting the weight. By streamlining ports, a technique known as "porting," one can increase flow capability and, by proxy, the volumetric efficiency of the engine.
#1805
Ah yes. In the past I've read all of FBRR's posts. I recall this one well. He's a very knowledgeable guy.
I don't know how much confidence I can put into the SEPST Smart Tune system. Its reliance on NB sensor voltage to establish (maybe "ball park" is a better word to use here) VE values is really suspect. I guess the only way to really make a judgement would be to make a dyno run and compare those VE's with what Smart Tune came up with. I'll have to think about that one. Maybe somebody has already done that?
"ball park". thats about right
#1806
#1807
I see the values in the VE tables as representing the actual true VE's. They may not be super accurate from the factory, or after me making mods. But the basis for good tuning depends on them being true. The ECU relies on that as well. That's why I use the AFR table for A/F adjustments in open loop. Which brings me back to why I want to know more about how Smart Tune creates them.
#1809
I suspect that Smart Tune does not rely on O2 sensor voltages to calculate new VE's. Their accuracy just isn't close enough. I'm going to try my own experiment. I suspect, and I may be way off, but I think it's entirely possible that Smart Tune does this for each cell that it has the data for:
First, it sums up the fuel pulses and calculates the number of grams of fuel used in that time slice using information stored with the calibration. The data has to be massaged a little but it's all there.
Next, since it was in closed loop toggeling fuel around a fixed 450mv (14.68 AFR for gasoline) it can compute the total number of grams of air that was most likely used to burn that fuel in that time slice. That's really the actual air flow number in grams. That number should be pretty close. If using E10 fuel the stoic is about 14.1 to get to 450mv. So that calculation might be off slightly.
Now, Smart Tune can also compute the theoretical air flow in grams for that time slice because all the information is available in the downloaded data to do so. The formula is easily available.
So, in conclusion, calculating the ratio of actual to theoretical like I just described will yield a VE value. Is that what Smart Tune is using for VE NEW.
#1810
Your making it to hard now.
If your ve's never come in , or they just keep changing on you and your chasing your tail? Look at your sample quality ,are the bungs proper? Is there times the sampling just stops? Does the bike do ok for a few days , then start unraveling?
When you do another smart tune run is it always making some good size ve corrections? Most bikes will not be capable of running closed loop everywhere the system lets you run it., and still be capable of feeding good data back to the ECM. This not only effects closed loop , but open loop as well.
