SEPro/SEStreet Tuner Information Thread
Old 12-09-2012 | 01:02 PM
1Canuck's Avatar
1Canuck
Originally Posted by Gilgamark
Kind of looks that way, I'm going to swing by my dealer to ask them. Is there a way to check the hardware, make sure it's operational?
there may be, but none that I know of.
  #1732
Old 12-09-2012 | 01:23 PM
Gilgamark's Avatar
Gilgamark
4th Gear
Originally Posted by RA51
you need to update the vci for it to work. Click on the cd with super tuner open, left side see vci/bolt. Updates the vci, needs to be connected to bike with power on.
I've made some progress: the computer has recognized the hardware and drivers are installed. But the software doesn't seem to know. Won't do anything. The update button is dead. Won't do anything.
Suggestions?
  #1733
Old 12-09-2012 | 05:02 PM
strokerjlk's Avatar
strokerjlk
Suggestions?
The sepst software works on 32 bit system .
You can get everything downloaded but the driver is 32 bit.
I don't have the newest software , but I understand it operates on 32 or 64 bit systems. If you have a 32 bit system you can tune your 2012 with the 2010 software . But it is probably just as easy to buy the newest software.
I converted my 64 bit to 32 bit , just for this reason.
New Ve's can only be generated with Smart tune enabled .
And the map has to be in closed loop or 14.6
  #1734
Old 12-09-2012 | 06:32 PM
Gilgamark's Avatar
Gilgamark
4th Gear
Problem solved: got the 2013 software from my dealer. Loaded without a problem, connected to my bike. I'm a go. Thanks
  #1735
Old 12-10-2012 | 09:24 AM
paud's Avatar
paud
Well thats odd. I had the 2010 version and loaded and worked fine on my 64 bit and installed the new version and that works on both 32 and 64
  #1736
Old 12-10-2012 | 11:08 PM
Gilgamark's Avatar
Gilgamark
4th Gear
Odd. Maybe the 2010 software I had was defective. I installed the 2013 software without a problem. Stage I air cleaner installed, remap completed. Definite upkick in horsepower and a nice deeper exhaust note. Running and sounding good.
  #1737
Old 12-11-2012 | 06:38 AM
strokerjlk's Avatar
strokerjlk
No it wasent defective . That s just the way the software was.
When I contacted the engineer in change of sepst. About this , I was told the driver only works on 32 bit . I then asked what do you do when a dealer upgrades there computers. I was told ( then) they do not recommend anything other than 32 bit or xp . Last year I was told by the same engineer , the new software will operate on either 32/64 bit. You just confirmed that .
  #1738
Old 12-11-2012 | 09:12 AM
paud's Avatar
paud
I need to clarify..sorry. I did load the 2010 verson on my Win7 64 bit computer and Super Tuner software worked. I even traded files from the 64 bit to a 32 bit computer with no problem. What I have NOT done is hook up the VCI to the 64 bit.
This weekend, I will try hook up the 64. I need a long cord as the 64 is in the house.
  #1739
Old 12-11-2012 | 10:43 AM
strokerjlk's Avatar
strokerjlk
There you go. Everything will work except communication via the VCI.
  #1740
Old 12-11-2012 | 11:21 AM
editbrain's Avatar
editbrain
I have the old super tuner 2010 version, and have zero issues with win7 64bit os.
