SEPro/SEStreet Tuner Information Thread
#1572
hi guys. i have a ping and believe its in the tune,my bike runs hotter then i believe it should too. any one know of a real good tuner near me? s.e pa? i have found one on this site - jd's cycle but they haven't returned a call from last week. I also think they don't or cant use the sert?
i had my bike tuned 2x and it still pings 15k miles later. Plus my dealer closed and the next closest one just uses canned maps.
2010 ultra limited,no cat-stock head pipe,cvo mufflers with fullsac baffles,andrews 54h cams and harley intake/k&n air cleaner.
Any help would be great.
Thanks-Ben
Thanks-Ben
http://www.roederracing.com/DynoTuning.html
#1574
Perplexed.
Something has me scratching my head...
I have done numerous run recording without "knock" engaged as directions say.
Recently I did another run, used the recording to change VE, saved, and re-loaded the new file to ECM. I then recorded a long regular run and noted where excess knock occurred. Excess knock occurred in the 90 map range and anywhere from 2000, to 4000 rpm. In those areas I also noted some new VE numbers after doing some tuning runs. So...what would come first: Raise the VE in those area's? Raise the AFR? Decreas the timing?
AND, another one. , so far I cant seem to dial in a smooth run for 6th gear from 2500 rpm up to 3400 rpm. Not much pick up in that area. The catch is, right after I bought the bike and right after the dealer tuned it, it was super smooth in this area. I have on occasion lugged the bike but it does not feel like that. In that area my AFR is either 13.1 or 13.
#1575
I have an 06 eg ultra bone stock. I am looking to buy the sepro tuner. My question is do I have 02 sensors and if not am i buying the right tool for tuning my bike? I plan on ugrading the ac and pipes but from what I'm reading in this thread i would still benefit from buying the turner and doing smart tune no matter what options the bike does or doesnt have. I know alot of people are buying the parts first. but cann i benefit from the tuner till I upgrade the bike?
#1576
#1577
[QUOTE=RA51;10343550]You have no 02 sensors, so you can not smart tune. Your bike runs a open loop map. I would see what shops can tune in the area an use the tuner they know. But talk to others in your area an see which shop can actually tune. SESPT will work but you will need a dyno tune.[/QUOTE
So can I just go and get a dyno without the sespt or do I need it to flash the ecu or can it be done without
#1579
#1580
What's your AFR there? Should be pretty rich, I think I have 12.5 or 12.8 or something. Remember also that smart tuning does not work over 80 map range - VE should be pretty much the same around 80-90-100.
So, make sure you are not running lean there.
Also, look into the knock retard events in the graphical log, do they occur on constant map load and steadily increasing rpm or do they happen when you decelerate quickly or switch gears? If you see that with certain map load and rpm range you always get knock events (with full 8 degs retard), try pulling back timing 3 degs at that map/rpm and iterate until you only get few occasional retard events.
I have tried several methods in removing all knock events but seems that at least for my 120R, I can not get rid of them completely
