SEPro/SEStreet Tuner Information Thread
#1441
FWIW, I hope I would have gotten the TTS instead of SEPST, it is so poorly supported and documented. This thread is about all there is. I even had to write some software myself to find the knock
#1442
OK i flashed the VCI with the map that came with the software 023CAR001. May be I was wrong to do this smart tuning in this very very hot weather. At night now it is 50 Celsius & it is 10 PM :WTF
I hope that the lugging & delayed response is from excessive heat around the engine. I will ship it tomorrow & hope that there will be a dyno in the Bike week that I will attend
The base map you picked up is for 2011 CVO engine with Screaming Eagle intake and race exhaust with 10.5 compression => high perf engine.
Now, you said you have done the smart tune few times. By all means you should use the smart tuned map rather than original map as it is always better than the original. Don't worry the VE values being different after each smart tune, if they are within 5% its good. If in doubt choose larger value, that may make your engine run richer but at least it does not break it like too lean may do.
Now that you are about to ship the bike, take your latest smarttuned calibration and set the AFR table to 0.925 everywhere from 20-80 MAP and 750-3500 RPM. The base map is very lean and in Europe 95E gas you get most everywhere has 10% ethanol causing the engine to run even leaner.
That should also help a bit with knock.
And do NOT check the "smart tune" box when flashing. If the last map you drove the bike with is the one you smarttuned, do NOT check the "reset adaptive fuel" box (preferred) but if you have already drove (more than few miles) with the original base map, you have to check the "reset adaptive fuel" when flashing the map with 0.925 Lambda
#1443
Hadye, here is what I can recommend, hope you still get this:
Ok have uploaded the file after making the changes? give me your thoughts, Do I choose Reset adaptive fuel when flashing or not ? I know that smart tune will not be selected
#1445
#1446
Always select reset adaptive fuel.
This table "adaptive fuel" is what the computer uses to calculate AFR from previous rides. If you were way off on the map before, you will want the computer to rebuild this AFV from your new map. Not doing so could be causing your problem.
#1447
#1449
Well, unknown really as the AFV is not documented well enough anywhere. I have a faint idea how the AFV works but I am not 100% sure. For what I know, if you did not check the "reset afv", it may cause the engine run slightly richer on the areas where you changed the AFR table away from 14.6 and if you touched also the VE tables. But if you did what I recommended (eg. just changed the AFR table from 14.6 to 13.5) then it should be ok. FWIW, running slightly rich does not break your engine, worst case you need a set of spare spark plugs (which I doubt very much). If you are in Kuwait, my guess is you get real premium gasoline without ethanol and the 5-10% ethanol gas in Europe will cause your bike to run few percents leaner anyway.
Thus: I would not worry about it unless you did make modifications to the VE tables.
If you take the SEPST and cable with you, take also the SEPST software CD. Worst case, you can find someone who can lend a laptop for you to fix it or have a shop in europe to help with it.
#1450
Am already taking my netbook with me to download pics from my Camera memory card so the whole "system" is in hand
