SEPro/SEStreet Tuner Information Thread
#1401
Some cams have extra timing built in. For instance, the SE204s have 8° that you need to adjust for in the timing table or the bike runs like crap after fitting them.
#1402
Location: Back in the Good Ole USA. South Carolina to be exact.
You can reload the file to both bikes to ensure that yes both bikes are running the same file.
I have posted a method numerous times for adjusting a timing profile.
You previously mentioned that you weren't seeing any knock retard in your recordings, but that you were hearing it. I tried to ask some questions to pursue some troubleshooting and was apparently ignored.
That leaves the timing charts. I dropped the timing from 2750 to 5000 rpm from 30 tp 80 kpa by 3 to 5 points. It reduced the pinging but hasn't quite gotten rid of all of it. I still need to tweak a few more cells. One interesting thing is that with the 3 to 5 point drop my bike was a tiny bit quicker than my sons. Before that change he could always pull away from me in a roll-on. This leads me to believe that his actual timing has to be different from what shows on his VCI. The working table from his VCI shows the same as the original, even though he never has had the pinging issue that I have.
How about you help us try to help you?
#1403
OK, Guys I spend alot of time reading your posts. very informative yet starting this is like an addiction , u don't know when u r going to stop.
I have a CVO convertible 2012, the base map that I started with was 023CAR001. After doing many runs about 10 with the suggested updated on VE tables I can feel a change in the bike being more smoother & responsive YET every time I hook the tuner there is always a change in the VE table & it is not a minor one , alot of cells are changin every time. Also from what I understood the base map doesn't have a single cell of AFR that have 14.6 so I guess the whole range is in open loop ?
#1404
When you select "smart tune" it overrides the maps AFR table and inputs all cells at 14.6 so the ECM will be looking for that and know if the cylinders are VE is high or lower then what is in the tables. That is why it gives you a warning when you select smart tune. If the ambient temperature and humidity are not the same from one run to the other then the VE tables will change. I do most of my tuning runs early in the AM before traffic and higher temps.
How is the bike running over all?
#1405
but the AFR by default in the map I chose is 14.3 not 14.6 thats why I don't have any CLB in my menu. As for the temperatures nowadays it is very "very" hot that's why I ride the bike for tuning only at night but in the same time & temperature. As for the bike it is running great for the time being & am satisfied with but got caught with the amount of information just wanted to know if there is another window of improvement
#1406
#1407
There are the original maps which show the CLB tables. With these maps the AFR tables don't give an option to adjust Lambda rather than AFR. When you want to trim the closed-loop area(s) you set the cells to 14.6 and then use the CLB tables to guestimate the AFR you will get based on the bias voltage you enter for the O2 sensors.
Some of the newer maps don't show the CLB tables in the list on the left. When you open the AFR table you will have the option to "Display as Lambda values". This is handy if you are adjusting things for non-pure-gasoline fuels such as E10. It also lets you enter values between 14.1 and 14.5 and these cells are then shown in bold, meaning that this is closed-loop. Values outside this range are not bolded and will be in open loop. So there is no need to adjust the CLB tables directly and these are hidden.
#1409
Billy
#1410
In your method you say to look for signs of detonation. I assume you mean simply looking for knock retard events - this is how I have been able to remove most of my ping but there is still some left. Is there other ways to detect detonation by just analyzing the data? My sepst samples the data only about twice per second so figuring out the exact affected cells is not exact science.
