SEPro/SEStreet Tuner Information Thread
#1211
With the SEPST do I have to connect it to the computer if I just want to do some data rides? Reason I am asking is I am leaving work early and wanting to do some data collection on the way home from work tomorrow. Could I just connect the VCI to the bike and press the button for record and then download the recordings when I get home?
The computer only has to be conntected to the VCI IOT activate the VCI for recording and then later for downloading.
#1212
#1213
Smart tuning is fun... Forgot to bring in the VCI with me yesterday. Well it would not have worked anyway. Did some runs today with "smart tune" selected on e download. Did some highway runs and some back road runs. Was even able to get some roll on up to 5500 RPMs. Took those runs and generated the changes in the VE tables. Just got back from the test ride on that adjust map and it is pulling better now and less decel pop at the 1500 RPMs.
#1214
Hi all, I'm back.
Last summer I replaced my PCIII with a SEPST, and did the autotuning to update VE tables, been happy with riding my scoot. Now I'm planning to do a cam swap in a few weeks, and trying to get my tuner ducks in a row ahead of time.
Decide to go with a Andrews 48H, in a twin cam 96 with upgraded AC and VH pipes. My searching suggests using a base map with a SE 255 cam since they are similar. However, the only super tuner map I can find for my Dyna/ECM also has the big bore, 103". So, my first question is: Should I use that base map and change the CID setting to 96.7" and then do logging/Autotune to update VE tables, or should I just use my current map and use data logging and auto tune to update the VE tables? The AFR maps look similar except my current AFR table adds more fuel in the 20kPa column.
Question 2: will doing the autotune keep me from running lean and frying the engine?
last question: I'm thinking I would like to get it dyno'd and tuned by a pro, and Jamie/FuelMoto is only a few hours away. How much more performance will I get from having it dyno'd vs autotune?
Thanks
Thanks
#1215
#1216
Hi all, I'm back.
Thanks
Thanks
As far as how much more performance your tuner can get depends on how well you tune your bike before putting it on the dyno. The dyno will help smooth out the torque curve. Mine was on the rollers less than 30 mins with only 3 cells needing changed. This showes how easy this cam is to tune in.
Billy
#1217
sest
I have the screaming eagle street tuner and have used the smart tune feature stage one for my 2012 ultra 103.it has made a difference in the way it performs but now im wondering should I have gotten a pro tuner?if so do I need to put the bike back to stock? can I save my maps and use the pro ?I plan on maybe selling the street tuner then.thanks
#1218
#1220
Thanks Foxster and Billyram for the replies. Unfortunately my home internet has been out all weekend and I'm here at work now.
Anyway, thanks for the good info. I looked at the file you mentioned Billyram, interesting you use a map for the 204 cam. I think the one I was looking at was 176AE004, but I don't have it here so I'm not sure. Can't say I know alot about tuning for performance, my butt dyno isn't real accurate. How much tuning did you have to do after adjusting your VE tables? did you adjust spark timing, AFR, or both.
Thanks
Thanks
