Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
just replaced the starter, the bike was fine befor i replaced it, got everything installed and tightened up, now NO POWER! no gauges, lights, anything, checked the grounds, fuses, connections, everything looks fine. only thing was when i was commecting the battery, i connected the ground first and i touched the red to the battery and it sparked, i thought it would have blown a fuse but i saw nothing blown.
What year is your bike? If it has a curcuit braker you could've fried it, or if it's newer you could've blown the maxi fuse. The maxi fuse isn't in the fuse block, it's a larger 50 AMP fuse.
