Codes U 1255 and Pn 670333-04
Hi Guys,
This is one of the best forums I've ever run across and my first question and post.
My bike won't start, a 04' Heritage Softail with EFI, although I have a good battery and all fuses are fine. The interesting thing is that I have power to the horn and lights, but my blinkers don't work and the security system doesn't respond. I turn the run/off switch to run and my fuel injectors fuel up but nothing to the starter.
I went through the diagnostic test and came up with the codes: U 1255 and Pn 670333-04.
I believe these are codes for the ECM???
Can anyone help me get out of this problem? Here in Ohio the riding days are winding down and I'd like to hit the road as soon as possible.
Thanks for any and all help!
Frank
Frank
RE: Codes U 1255 and Pn 670333-04
WELCOME ABOARD THE FORUM FROM OKLAHOMA!! Hello Frank. I believe the code is "Missing serial data error from the Speedometer//TSSM" (turn signal control module) Try going to search in this forum & type that code in. You will find a bunch more info. I believe you will find a diagnostic procedure to. Anyway Im not sure how to add a link in the site to another forum, otherwise I would have. GOOD LUCK.
TOOLBOX
TOOLBOX
