Stage 1 Download
Stage 1 Download
I hope I am in the right area for this question, if not, I apologize. On my 2010 FLSTC, I have installed V&H staggered slip ons, SE intake and Xied. I am getting both yes and no's to the question: should I have the stage 1 remap done? I'm so confused and pretty much broke, so if not necessary or a waste of money, please advise.
Because it increases the pulse width of the injectors across the board regardless of map pressure, your gas mileage will decrease.
You can use what you've got. Most people go with a decent fuel management system to richen your AFR to optimal levels. There are many good systems out there. You can get a Power Commander V from www.fuelmotousa.com. He's a sponsor here and has many happy customers. It'll run you right at 300.00, but he'll pre-program it for your specific set-up and you won't have to worry about a dyno afterwards.
I would not. In my opinion both the canned factory downloads and Xieds are weak. If your low on funds and want to get the job done fast and easy, I would take the xieds out (put it back to factory) and install a TFI (Dobeck performance) piggy-back fuel controller. It will fatten up the A/F ratio across the board and is something you can do yourself without dyno time. Not complicated to adjust & great support after the sale. Your going to get a lot of opinions on this subject but I think for the money you can't go wrong. And if your a Veteran I believe you may get a small discount.
No need to get the stage 1 download. It only adds a small amount of fuel and will still be on the lean side anyway. The vets get a rather large discount on the TFI from Dobeck.
http://www.dobeckperformance.com/
Just ride and have fun. No need to fret.. If you are not happy with the ride, then perhaps something can be done, and that depends on what you want. The XIEDs do what nightrider says they will do and they do affect closed loop operation a bit because the ECU uses the adjustments/learned values from closed loop operation in the open loop areas too. Not the best you can do, certainly, but much better than nuttin.. The HD down load is a waste of $$$.
Just ride the bike, there is absolutely no need to fret. Lots of salesmen on this board suggesting fancy systems that separate you from your cash.. If you think you want one, be sure to do some research. A poor tool for you is still a poor tool, regardless of discounts..
