F.I. tech question
F.I. tech question
I asked my dealer about a factory program to make my bike ( stock 07 sporty) run richer, but he said there was no program to do this. Is he right, or is there a upgrade that will richen up my mixture, I'd like to install a set of slip-ons, without spending the $s for a sert. Anyone know for sure, thanks
RE: F.I. tech question
Stage I Legal cal is the only one that you can install, as it is for the SEAC and SE Legal pipes.....
This is off of the cal menu that HD works off of....
unsure of what you have (883 or 1200)....
Vehicle Configuration Summary
Region: United States of America (Remaining 49 States)
Model Year: 2007 Platform: Sportster
Model: None Selected Exhaust: None Selected
ECM/ICM: None Selected Cylinder Heads: None Selected
Engine Displacement: None Selected
Fuel Injectors: None Selected
Air Cleaner: None Selected
Throttle Body/Induction Module: None Selected
Cam Shaft(s): None Selected Pistons: None Selected
Search Results: 6 Applicable Calibration(s)
Street Legal/Race: Street Legal
Part Nbr: 32153-07B/DT
Available On: Digital Tech
Calibration ID: 32153-07B
Description: Stock OE
Restricted Power: Unrestricted - (Full Power)
Req'd Configuration:
Model Year: 2007
Platform: Sportster
Model: XL1200C, XL1200R, XL50
Exhaust System: Original Equipment (Legal)
ECM/ICM: 32140-07,32534-05B
Cylinder Heads: Original Equipment
Engine Displacement (cc): 1200
Fuel Injectors: 07 XL Injector (27706-07)
Air Cleaner: Original Equipment
Module: Original Equipment
Cam Shaft: Original Equipment
Pistons: Original Equipment
O2 Sensor: 27719-07
Part Nbr: 22718-07/DT
Calibration ID: 22718-07
Description: Stage 1 Legal
Model Year: 2007
Platform: Sportster
Model: XL1200C, XL1200R, XL1200L, XL50
Exhaust System: H-D Slip-On & SE Street Performance (Legal)
Air Cleaner: SE High Flow
O2 Sensor: 27719-07
Model Year: 2007
Platform: Sportster
O2 Sensor: 27719-07
Part Nbr: 32143-07B/DT
Calibration ID: 32143-07B
Model Year: 2007
Platform: Sportster
Model: XL883, XL883C, XL883L, XL883R
Engine Displacement (cc): 883
Fuel Injectors: 07
Model Year: 2007
Platform: Sportster
O2 Sensor: 27719-07
Model Year: 2007
Platform: Sportster
O2 Sensor: 27719-07
Model Year: 2007
Platform: Sportster
O2 Sensor: 27719-07
Model Year: 2007
Platform: Sportster
Fuel Injectors: 07
BlockHead96
10-12-2017 08:26 PM
