License Plate/Light Kit
I just purchased a used chrome license plate/light kit (68230-97B) on ebay (item E on page 644 of the 2010 Motor Accessories catalog), but the wires were cut, so no plug and play. Since I don't have instructions or the original connectors, how is the best way to wire this item?
The catalog description states "running lights/brake." Is it possible to wire this item for signals too, or would that be too much?
http://www.harley-davidson.com/en_US...ts/-J01565.pdf
if it were mine I'd go to the dealer and pickup the following so as not to have to cut your factory harness under the seat
72114-94BK - Connector
72154-94 - Connector lock (probably not needed)
but realistically speaking it's a breeze either way you choose to do it. simply match up the colors to the wires on the empty connector under your seat.
Black
Red/Yellow
Orange/White
Blue
Black
Red/Yellow
Orange/White
Blue
OK, 9 months later I get-around to installing the chrome license plate light kit. The installation is uneventful, until I get to that darn deutsch connector.
I purchased the 72114-94BK male connector which comes with 4 pins, and the instructions (http://www.harley-davidson.com/en_US...ts/-J01565.pdf) show the 4 wires from the lights being connected into 2, these wires are red and blue.
The female connector under the seat has 4 wires, black, red, red/yellow stripe, and what appears to be orange (there is no blue wire, or orange with a stripe that I can tell).
Which wires go where?
