Super Tuner base map calibrations
Have the new software 32111-11 and was going through all the base map calibrations. I cant seem to find one closest to mine. Anyone have any ideas or should I just load everything in manually?
2009 Street Glide with 103 build
2009 Big Twin 103 Stage 2 race kit P/N 29893-07a
se 255 cams
Heavy breather 29253-08A
V&H true dual exhaust with Rinehart slip on
se 255 cams
Oh and I am not sure if it matters but it was dynod when the build was complete, however I have since added the heavy breather and true duals
EDIT: I did find my map on there now. Do you think this is a good place to start? I know the breather is different
Application: 2008-09 Touring with 02 sensor
Configuration 1690 Stage 2 Race
SE Air Breather PN 29260-08
SE big Bore cylinder Pn 16549-99 or P/N 16549-99
SE big Bore pistons P/N 21966-09
SE 255 Cams P/N 25638-07
Race Exhaust
ACR Disabled
Race Exhaust
ACR Disabled
If you're looking to run the smart tune, why load another map, just start the smart tune with where you're at now. Personally I don't think the a/c change will have changed anything air fuel wise and not knowing what exhaust you had on when you dynoed it I'm not sure the exhaust you have on it now will need a re-tune from your dyno tuned map.
