Troubleshooting for 2008 FLHX cruise control
Cruise Switch light DOESN'T come on....
Here's one! The light on the Cruise Rocker Switch does NOT come on - so I can't do a diagnostic run thru. Last summer I had a shop change the rear tire and give the bike a once-over before a 7,808.l mile trip. When I left, I realized the brake pedal didn't make the cruise kick off. The cruise worked fine all through the trip, but conked out a few days ago. I had the bat wing and dash all apart to check the switches and they appear fine - all connected, nothing loose. I also checked the brake light - and the front brake lever lights it up - but the rear pedal does NOT. I'm guessing the switch on the rear brake went bad.....sound reasonable? The hand-grip cruise switch is tight - but it COULD be the culprit too - am I going in the right direction?? Any ideas how to test the rear brake switch??
Thanks!
Robert Ferguson
Thanks!
Robert Ferguson
harleybob815
16
12-31-2022 12:35 PM
