O2 Eliminators
Old 10-04-2006, 02:04 PM
LockNut's Avatar
LockNut
LockNut is offline
Default RE: Update: O2 Eliminators
Mine was on the bike and powered up when I did it.
  #32
Old 10-04-2006, 02:44 PM
Shrug's Avatar
Shrug
Shrug is offline
This is not a PCIII issue. This is an inept tech/dealer issue. The PCIII is fine. Install the o2 eliminators and load Map M811-003. It closely mimics the HD staggered slip-ons and AN Big Sucker. Be sure to zero the throttle.
  #33
Old 10-04-2006, 03:24 PM
LockNut's Avatar
LockNut
LockNut is offline
You are right about the inept part. I bought a PC from FuelMoto with the stock map 812-001. Bike is running great. My next item will be the AN Big Sucker (and I will be leaving the pipes alone) and some sort of AFR monitor. I'm currently looking in to the Innovate Motorsports LC-1 Wideband o2 or the PC's Wideband Commander for tuning.
  #34
Old 10-06-2006, 05:10 PM
211Chuck's Avatar
211Chuck
211Chuck is offline
LockNut
Hang Around
Status: offline According to Dynojet, without installing the O2 eliminators, "the PC will not be able to make the proper fuel changes anywhere below 50% throttle". I am experiencing surging below 50% throttle which is expected without installing the eliminators
I have a 2007 Ultra Classic, it started surging at about 800 miles after
(my wife bought it for my birthday) I took it to the shop she bought it
at (Carolina Harley Davidson) and they installed Harleys Parade map
in it and for the rest of the month and 6,000 miles it runs perfect with
no surging at all...
The Parade Map effects from idle to 10% throttle which is about where
you hold the throttle going down the highway at a steady speed..
Eric is the man to speak to and his number is 704-867-2855 if you
would like to speak with him.
Good Luck and Ride Safe!!
  #35
Old 10-07-2006, 09:07 PM
Honus's Avatar
Honus
Honus is offline
I noticed Cobra is releasing a closed loop version of their DFO this month, using the OEM O2 sensors.
  #36
Old 10-09-2006, 11:18 PM
LockNut's Avatar
LockNut
LockNut is offline
I saw it here. Looks cool but...
It uses the O2 sensors in the bike which I had read are narrow band. For it to work great, I think it would need wideband sensors in the pipes.
ocezam
11
10-11-2017 10:58 AM
KumaRide
07-11-2013 07:05 PM
dyolfknip
05-22-2013 09:43 AM
Mechano
05-21-2009 02:25 AM
robaube
02-21-2008 08:04 AM
Quick Reply: O2 Eliminators
