no power to ignition
2006 Road King Police, I'm not getting power to the ign switch or anything else when the switch is turned on, battery is up and I have power on the Acc. side but when switch is in the run/start position I'm not even getting power to the switch anymore. Is this the EFI relay?
I checked the maxi fuse. Switch has power leading to it in the off position, turn the switch on and all three leads going to the switch are dead. Power supply in middle - dead, power out - dead, acc. out - dead turn switch to off position, power supply wire in middle is hot and other two are dead. Turn switch to acc. and power supply is hot and wire on left is hot.
