power commander v not connecting to pc
2010 heritage power commander v isnt connecting to computer.what i dont understand is if i twist the throttle the numbers move in the upper right hand corner.there is a white box in the screen that used to show the tune but its blank.all the tables read 0.tried 3 different cables,restarted with it connected to make sure drivers loaded,and held the cable into the power commander.2 months ago it worked fine.any ideas?
echo:
"get map" = retrieves map from Power Commander
**if there's a doubt youre connected, click on "information" and it will read your PCV serial number and model telling you it "Sees" the PCV
"save map" - Saves the map currently being VIEWED to a file on your PC (you can save before editing it, that way you can reload your old one if you screw up.)
"load map" - Loads whatever map is currently in view, onto the PCV. At this point, you can yank the cord, turn it off, whatever, and it's burned onto the PCV EEPROM.
You can open / view and compare any combination of maps, and as long as you don't "load map" onto the PCV, then you can just close the App, and go on about your business, no harm no foul.
Really couldn't be a whole heck of a lot simpler...
"load Map" doesn't exist on the PCV
echo:
