’09 FLHTP PCV map
’09 FLHTP PCV map
I have a ’09 FLHTP. I have put on V&H basic slip-ons, VO2 naked intake and the PCV. Part of the question is about the map for the PC. There is not one available for this bike/setup. Part of the question is about the bike itself. I know it is a 103ci engine, however the rest of my information is not so clear. The mechanics at the HD shop I bought it from say that the pistons are higher compression, the ECU programming is different and the cam is different from the stock 96ci FLHT. I have been using map M15-003-007 96ci engine, Vance & Hines basic slip-ons, Screaming Eagle air filter, Stock ECM, Rev Xtend enabled which is a little lean otherwise it seems OK. I have tried some of the maps for close 103ci engines/options without improvement. If someone knows more about the engine itself and if the mechanics are correct let me know it would be a big help right there. If you have suggestions about how modify map *007 that would help also. I live a long way from a tuning center and the autotune is a little pricey.
